Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
wheel offset?
Old Apr 14, 2010 | 06:52 PM
messeduprex's Avatar
Default wheel offset?
i'm looking at wheels for the tsx and im a little confused on what kind of offset i should run with 18 x 8's. i dont want to roll the fenders.
Old Apr 15, 2010 | 04:59 AM
WhiteSlips's Avatar
Default Re: wheel offset?
We just recently bought some 18x7.5 +35 and with 0 camber here is how they fit.
On an 18x8 I would got with an offset in the 40s if you don't want to run excessive camber or roll the fenders. Is your car lowered or going to be lowered?
Old Apr 18, 2010 | 02:01 PM
it's going to be lowered. with either tein comfort spec's, or flex's
Old Apr 21, 2010 | 06:39 AM
MrHeeltoe's Avatar
You are going to need to stay 45+ on the offset, sorry I can't be a bit more specific...
I am going to run 17x9 +48, I am expecting to have to do a little fender tweaking and run extra camber.
Old Apr 24, 2010 | 09:41 PM
zumbi's Avatar
Im running 18x 8.5 , 42 offset with espilar springs. I have no rubbing at all. Infact the rears could use a 5mm spacer.
Old Apr 27, 2010 | 03:40 PM
MrHeeltoe's Avatar
zumbi, you are in RSM? Like 10 min from me
Old Jun 26, 2010 | 09:12 AM
Frog's Avatar
I'm running Weds Sa55m 18x8 with a +35 offset and Yokohama AD08 225s. Lowered on Tein S.Tech with Koni Sport damper on lowest perches.
0 camber in front and I had to roll the fenders.
The rear are a lot more difficult to roll, but they are nonetheless with 2.8 deg of camber and only rubs slightly at full compression. I probably just need to do a better rolling job, that's all. If you're lowered, you'll have to run camber with this offset.
Depends what you like, I like to be flush with the edge of the fender, some guys like to be tucked in and run +45 instead.
+40 front and +35 rear with an 8" wheel would be the best setup, IMO.
Lots of info, but I searched high and low for the same info before I bought.
oskarsEG6
Nov 16, 2011 03:21 AM
meric0786
Jul 10, 2011 11:16 AM
IntegraDriver
Jun 14, 2006 06:39 PM
mekanism
Jul 4, 2005 10:43 AM
osbornsm
Sep 1, 2002 08:41 AM
