what is this flange for?
Old Jan 17, 2006 | 10:01 AM
weiRtech's Avatar
OG Fabricator
Default what is this flange for?
i made this for a customer but was not told what engine code it was for. all i know it is a TOYOTA of some sort. any help is appreciated.
i made these at the same time as well, obviously i know what they are for.
Old Jan 17, 2006 | 10:11 AM
Evile140's Avatar
Default Re: what is this flange for? (weiRtech)
Sorry, I don't know what they are for, but what kind of file do you need to cut a flange?
Would this work?
http://www.eville140.com/Heinlin3tc.dxf
Thanks
Randy
Old Jan 17, 2006 | 10:17 AM
weiRtech's Avatar
OG Fabricator
Default Re: what is this flange for? (Evile140)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evile140 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, I don't know what they are for, but what kind of file do you need to cut a flange?
Would this work?
Thanks
Randy</TD></TR></TABLE>
hey randy, for some reason when i "save as" it saves the file in a txt format, not dxf. i can read dxf, dwg, iges... among others. if you want you can email it to me.
weirtech@cogeco.ca
Old Jan 17, 2006 | 10:34 AM
Evile140's Avatar
EMail sent
Old Jan 17, 2006 | 10:36 AM
discrete's Avatar
Off topic -
Out of curiousity, whats the thickness of that flange?
Old Jan 17, 2006 | 07:40 PM
monster007's Avatar
Looks likeone port is larger then the others. 3SGET 3rd gen. Japan spec. it's not the same as the U.S. spec 3SGET
http://www.monster-turbo.com
Old Jan 17, 2006 | 09:46 PM
CarTunr22's Avatar
Default Re: what is this flange for? (monster007)
I'd second the 3sgte part, but i know for a fact that its not from the 2nd gen motor.
Old Jan 17, 2006 | 11:20 PM
weiRtech's Avatar
OG Fabricator
the far left port is larger than the others. i thought that was kinda odd.
it is 1/2" mild steel.
Old Jan 18, 2006 | 05:01 PM
monster007's Avatar
Default Re: (weiRtech)
So it is the "2nd gen" engine.
Old Jan 18, 2006 | 05:35 PM
Evile140's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">hey randy, for some reason when i "save as" it saves the file in a txt format, not dxf. i can read dxf, dwg, iges... among others. if you want you can email it to me.
weirtech@cogeco.ca</TD></TR></TABLE>
Did you get my email with the file?
Thanks
Randy
Old Jan 18, 2006 | 06:32 PM
weiRtech's Avatar
OG Fabricator
Thanks
yes i did randy, do the corners rads on the ports have to be so small? can they be a bit bigger? it would make it much easier to cut them.
Old Jan 19, 2006 | 03:42 AM
Evile140's Avatar
I will see if I can change it a little bit and send you a new file this evening. How big of a radius on the corners do you need?
Thanks
Randy
hatchinprogress
Mar 19, 2006 03:17 PM
ineedhelp
Welding / Fabrication
16
Jul 29, 2005 01:06 PM
Jockobo
Jun 29, 2005 03:21 PM
integlspwr2k
Aug 30, 2004 03:07 PM
Hoosier Daddy
Dec 16, 2003 08:46 PM
