weld through primer?
Old Aug 28, 2008 | 06:53 AM
dfoxengr's Avatar
Default weld through primer?
Anyone use this stuff?
is it just a zinc cold galvanizing compound? or is it something different?
im assuming different, but just wanted to check
Old Aug 28, 2008 | 06:55 AM
B18CXr's Avatar
Default Re: weld through primer? (dfoxengr)
weldable primer is fine to use, great stuff
Old Sep 5, 2008 | 07:20 PM
Sobe_Death's Avatar
So is welding through the zinc rich primer safer than welding through galvanized metal?
Old Sep 6, 2008 | 01:23 AM
9295EJ-t's Avatar
all it is, is a can of zinc based paint, and it is used for galvanize repairs...
something is galvanized, the weld breaks, you fix it/re weld it, and instead of re dippin it in the galvanize tanks, they spray over the repaired area with this....
i worked in the galvanizing industry for a while, i was the guy "dippin" the **** in the gigantic molten pot of zinc (aluminum, and nickel was also in the "pot") with overhead cranes, and i occasionally broke ****.. and the other guys would fix it...
Old Sep 6, 2008 | 04:07 AM
dfoxengr's Avatar
Default Re: (9295EJ-t)
sounds like youre saying you paint with weld thru after you weld, but youre supposed to before right...
Old Sep 6, 2008 | 06:17 AM
Flashmn's Avatar
Default Re: (dfoxengr)
right.
Zinc spray is something else.
weld through primer is primer that allows to be welded through it without it burning off and thus it makes a barrier that is more protective than just welding it and painting it afterwards. I use weld through primer in all of my repairs.
Old Sep 7, 2008 | 09:43 AM
9295EJ-t's Avatar
it burns.. but it wont contaminate the weld..
matmcg
Paint and Body
18
Mar 23, 2008 09:28 AM
sniggler316
Paint and Body
12
Jun 18, 2007 09:00 PM
Mistermark
Welding / Fabrication
18
Feb 17, 2006 11:37 AM
JCracer723
Dec 15, 2005 04:47 PM
Lost Type R
Oct 10, 2002 11:19 AM
