Weld progress pics...
Old Apr 13, 2007 | 04:53 AM
  #26
*Boostwerks*'s Avatar
Default Re: Weld progress pics... (Niles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Niles &raquo;</TD></TR><TR><TD CLASS="quote">The rule of thumb I've been taught is one second for every 10 amps. I always tack on a few seconds beyond that for good measure if it glows for a while like RC was saying. So if you're welding that sched pipe at 100 amps, you would need 10 plus seconds post flow </TD></TR></TABLE>
Thats a really good rule to go by! Thanks!
Old Apr 13, 2007 | 08:02 AM
  #27
m R g S r's Avatar
Default Re: Weld progress pics... (Boostwerks.com)
Well first, the WG elbow meets the collector at a 90 degree angle....so right there the exhaust gasses have to take a 90degree turn, then they have to flow through the long WG elbow pipe another 180deg. to hit the WG.....I dunno if it works then cool, but you don't think boost will spike at all?
Old Apr 13, 2007 | 12:32 PM
  #28
Pat McGroin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a really good rule to go by! Thanks! </TD></TR></TABLE>
I have also heard the same thing on Ron Covell's tig welding video.
Old Apr 13, 2007 | 02:44 PM
  #29
Default Re: Weld progress pics... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Well first, the WG elbow meets the collector at a 90 degree angle....so right there the exhaust gasses have to take a 90degree turn, then they have to flow through the long WG elbow pipe another 180deg. to hit the WG.....I dunno if it works then cool, but you don't think boost will spike at all?</TD></TR></TABLE>
Almost all manifolds currently produced, have a WG flange that meets the collector at 90 degrees. The fact that the gases have to make the additional 180deg turn, does almost nothing to the WG's efficency. As long as the initial WG hole in the collector is large enough, ported, and a little ways past the convergence point of the collector, the WG will work just fine.
I personally havn't had any issues, nor has a single customer.
However, this 90deg setup is still far from ideal for large turbo/high boost setups, which is why I'm coming out with my "ultimate" manifolds.
  #30
Default Re: Weld progress pics... (Pat McGroin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat McGroin &raquo;</TD></TR><TR><TD CLASS="quote">
I have also heard the same thing on Ron Covell's tig welding video.</TD></TR></TABLE>
Wasn't that video posted here at one point? I looked for a couple weeks ago, but I couldn't find it.
Old Apr 14, 2007 | 03:51 AM
  #31
Wasn't that video posted here at one point? I looked for a couple weeks ago, but I couldn't find it. </TD></TR></TABLE>
http://thepiratebay.org/search/covell
Old Jun 13, 2007 | 07:56 AM
  #32
blue2000em1's Avatar
I don't know much about certain welds,But I can tell from a shitty weld and a very nice weld,and that **** is done right.
Old Jun 13, 2007 | 08:55 AM
  #33
JDMs1eeper's Avatar
Keep up the good work Bryson
builtsinglecam
Nov 3, 2008 03:44 PM
BumbleBee Tuna
Jun 20, 2007 08:39 AM
diegospecaccord
Nov 24, 2006 11:52 AM
Jon Like Wh0a
Aug 14, 2005 12:34 PM
Works Euge
May 19, 2004 01:22 PM
