ToxicFab's Fabrication pics!
Old 02-06-2012, 07:41 PM
  #751
OG Fabricator
russianvr4's Avatar
Default Re: ToxicFab's Fabrication pics!
Originally Posted by ToxicFabrication
Pretty sure I've posted pics of my bevels, I see you saying your knife edge beveling and welding at 35smps for sch10? Not sure how your pulling that off or if your making a few passes.
But I do run a very specific bevel, and run about 65-75amps, run a single pass, no pulse and come out with great penetration.
Same goes for sch40
Hope this helps
yeah, i found knife edge bevels to be best. i use a very steep angle and minimal amperage. takes a little bit longer but it was easier for me to produce welds that looked nicer with minimal HAZ
Old 02-06-2012, 07:43 PM
  #752
OG Fabricator
ToxicFabrication's Avatar
You got the right idea Russian. You should post more pics of your work, I've been slacking.
I'll post some titanium stuff now
Old 02-06-2012, 07:47 PM
  #753
OG Fabricator
russianvr4's Avatar
ill post some up tomorrow or wed, built a pretty cool crossmember for a trailblazer SS out of chromoly, 1st time welding it and i gotta say i like it!
Old 02-06-2012, 08:27 PM
  #754
OG Fabricator
here are some new pics...
titanium down pipe for a evo
random pic
gas tank per customers measurements (more pics when finished)
here i am...
Old 02-06-2012, 08:37 PM
  #755
SovXietday's Avatar
The more pics I see of titanium the more it looks like it flows like crap. How much of a pain is it to weld?
Amazing as always, I have no idea how you get the consistency down in the runners like that, amazing.
Old 02-06-2012, 08:40 PM
  #756
OG Fabricator
russianvr4's Avatar
good stuff! lets see the inside of that downpipe :D
Old 02-06-2012, 08:42 PM
  #757
OG Fabricator
russianvr4's Avatar
it really doesnt flow, welds more like aluminum. you also have to make sure you feed the filler into the hottest part of the puddle otherwise it will stick.
its kind of a pain in the butt but its my favorite metal to weld.
Old 02-06-2012, 08:46 PM
  #758
OG Fabricator
not sure where you get that, it welds beautiful.
how did i know you would ask that
took this pic just for you
coverage could have been better but i think it turned out just fine...
Old 02-06-2012, 08:48 PM
  #759
OG Fabricator
russianvr4's Avatar
it looks like art my friend!
i've always wondered why you see the starts/stops of the gas coverage on the inside. not enough flow/coverage from the purge?
Old 02-06-2012, 08:49 PM
  #760
OG Fabricator
here is a unfinished titanium shift ****
Old 02-06-2012, 08:50 PM
  #761
OG Fabricator
you thought for a second i didn't purge it huh... huh... HUH???
Old 02-06-2012, 08:54 PM
  #762
OG Fabricator
Pretty much, I'll post more pics later, that's the only spot with color. You can see towards the top back there is zero color, turned the gas up about 5cfm and all color went away.
Old 02-06-2012, 10:22 PM
  #763
FabChild's Avatar
Work looks awesome man!
Old 02-06-2012, 10:24 PM
  #764
all_motor_mike's Avatar
god damn ur good collin!
mike
Old 02-07-2012, 03:36 AM
  #765
OG Fabricator
Thanks guys, I'm going to try and get some more pics today. Some very interesting projects coming soon
Old 02-07-2012, 11:58 PM
  #766
RickyLee53's Avatar
Out of interest what does the downpipe weigh and what did you charge for it PM if you like?
Old 02-08-2012, 04:38 AM
  #767
OG Fabricator
It came in at 4lbs on the money, I did use a half inch flange and solid half inch hangers. So that did add do it a bit. Plus its .065 wall tube.
-Collin
Old 02-08-2012, 04:42 AM
  #768
Homosexual by choice
exgr's Avatar
beautiful work sir!!
Old 02-08-2012, 05:06 AM
  #769
OG Fabricator
Thank you, gona try and snap some pics from around the shop today
Old 02-08-2012, 06:53 AM
  #770
nikko040103's Avatar
good job sir! welds are perfect!
Old 02-08-2012, 07:47 AM
  #771
OG Fabricator
9bells's Avatar
Looks good. I found that it was harder to tell when it was biting through to the inside like you did. Less consistency then stainless for sure. Pie cuts are so annoying, but so cool at the same time. .065" should last on a DP. It's not real happy with life above 800, but a little thicker like that helps.
Cool stuff to play with for sure.
Old 02-08-2012, 07:51 AM
  #772
OG Fabricator
9bells's Avatar
It's because Titanium is so desperate to bond with oxygen in it's molten state. Anything less than a near-perfect 99.5% argon/inert environment will show colour. Stainless you can get away with alot worse.
Old 02-08-2012, 06:17 PM
  #773
tyguy252's Avatar
**** looks sick
Old 02-08-2012, 06:54 PM
  #774
Fastflyguy's Avatar
Very nice !
Old 02-09-2012, 03:07 AM
  #775
OG Fabricator
Thanks guys, very busy but I am keeping up with some pics, post them when I have some time.
Quick Reply: ToxicFab's Fabrication pics!
