S488 Turbo Manifold w/twin 50mm gates, Intake manifold w/8 injectors
Old 04-18-2009, 10:21 PM
.RTErnie's Avatar
Default S488 Turbo Manifold w/twin 50mm gates, Intake manifold w/8 injectors
I just finished this intake manifold, turbo manifold, and fuel rails.
Setup is for Sean @ NewGenMotorsports in Las Vegas Nevada. It's for his drag SRT-4. Turbo is a Borg Warner S488, Accufab 90mm TB, and NewGen Turbonetics 50mm wastegates. Enjoy!
Old 04-18-2009, 10:23 PM
redboost10's Avatar
Default Re: S488 Turbo Manifold w/twin 50mm gates, Intake manifold w/8 injectors
at least i know your still alive eric.
Old 04-18-2009, 11:37 PM
JDM KID 510's Avatar
Very Nice.
Old 04-19-2009, 12:23 AM
AspectIndustries's Avatar
Sweet dude! Your work looks better by the day.
Synik!
Old 04-19-2009, 05:52 AM
Blown90hatcH's Avatar
Looks good man, but those wastegate angles are going to suck. Glad you have two big gates on there.
Old 04-19-2009, 08:23 AM
Teglove2's Avatar
Ernie that t4 flange looks hella thin....and I would HIGHLY suggest welding those seams on the inside or a crack will stem from the inside...just a thought
Old 04-19-2009, 09:09 AM
DESTROYER's Avatar
/\ Ditto, but still looks ****.
Old 04-19-2009, 09:37 AM
Nick Z32's Avatar
yeah besides the T4 flange bieng so thin
I love it
Old 04-19-2009, 12:39 PM
.RTErnie's Avatar
It's actually a T6 flange. That may be why it looks a bit thin. 3/8" flange...could've been 1/2".
If I weld the inside of the collector I'm creating a large porous pocket that WILL crack. It's been in my experience that by not welding the inside of the collector I will prevent cracks from forming...and reforming (as welding up the crack that has been generated only closes the porous pocket again)
Weld porosity = the suck.
The wastegate is not the priority in this setup... which I guess you noticed
Old 04-19-2009, 01:27 PM
k24em2's Avatar
That looks terrible Eric. It'll probably be slow, high 13's if you're lucky.
Old 04-19-2009, 02:35 PM
paulzy's Avatar
damn, haven't seen you or your work in a while.
Old 04-19-2009, 03:03 PM
something different
redzcstandardhatch's Avatar
thats one of the more beautifully crafted manifold i've ever seen.
how much power does this thing need to make to justify that crazy turbo?
Old 04-19-2009, 08:19 PM
denske's Avatar
hope he has enough juice to getting that thing going. nice fab work.
Old 04-19-2009, 08:43 PM
90blackcrx's Avatar
**** looks sick Eric, glad to see you're still welding. As for the wastegates, I'm sure the car won't see low boost, plus its divided.
Old 04-19-2009, 10:12 PM
.RTErnie's Avatar
He's shooting for 1100+
From what I was told it's a custom auto gear box and it will have LOTS-O-NAWZ.
Thanks for the comments guys. I've been busy with my day job (Performance Calibration Engineer) and I haven't had much time to make it out to the garage. I also spend too much time over on Evom now that I'm an Evo fan boi.
I'll have pics up soon of a spec miata that's been in my garage for over a month now lol. I just got an S14 dropped off that's getting some special 2JZ sauce. I'll have to post pics.
Old 04-20-2009, 09:30 PM
PTPbracket's Avatar
looks awesome as always, I have one of your manifolds as my background from a long time ago.
Old 04-20-2009, 09:34 PM
01DC4's Avatar
wow very nice!
Old 04-20-2009, 10:45 PM
96supercharged's Avatar
Where did you get those injector bosses?
Old 04-21-2009, 02:26 PM
Wheels 2's Avatar
Wow great work.I wish that i could weld like that.
Old 04-21-2009, 10:44 PM
93LSivic's Avatar
Intake looks identicle to an AMS EVO intake. Everything looks real nice!
Old 04-22-2009, 08:39 AM
T4 Neon's Avatar
X2. Looks great Eric, glad to see you're still working on cool stuff.
Where'd you get the intake manifold flange / runners? If I ever decide to redo my intake manifold someday, I'd like to know where to get one.
Old 04-22-2009, 12:14 PM
New User
slow_spool's Avatar
looks good
Old 04-22-2009, 12:59 PM
GUNNAR's Avatar
Looks very nice Eric.
Old 04-23-2009, 03:59 PM
Baxt3r's Avatar
I lathed up the runners and the bellmouths for Eric. The runners have a 2 degree internal taper on them. From our calculations the manifold is approximately 6.1 liters in volume: it's massive!
Old 04-23-2009, 11:53 PM
.john.'s Avatar
doesnt really seam like much penatration on any of the welds? i can understand pockets being a problem but if you weld all the way through then theres no pocket right? this has to be more prone to cracking than full penatration? ive made a ton of manifolds and have had problems in the past with small beveling and lack of penatration but since large bevels, full penatration and purging ive not had one issue. idk, seems like with a setup creating that much heat you would want to do whatever you could to make the manifold be one solid piece. the fitment looks great though, oh and wastegate control is still very important on high boost cars. bad placement and angle with still cause fluctuations and spikes, even when venting small amounts of air. i usually really like your stuff but this one seems a little more "show" and less "go".
Quick Reply: S488 Turbo Manifold w/twin 50mm gates, Intake manifold w/8 injectors
