rust hole in trunk!?what to do
Old Aug 20, 2009 | 06:15 PM
HI91EFHB's Avatar
Default rust hole in trunk!?what to do
im about to buy a 90' integra DB1 everything is perfect,but theres one rust hole about 7 inches long and 1 1/2" inch wide
what should i do!?
my friend said cut it off and junkyard the exact same piece from a junk car and weld it on!
anyone got some suggestions?
i want to fix the rust hole before i paint it and before my trunk becomes a pool.
what do i need?
materials?
things to read?
links?
sorry if this has been covered before,thanks in advance.much appreciation.
Old Aug 21, 2009 | 08:57 AM
RC000E's Avatar
Default Re: rust hole in trunk!?what to do
Depends on the location. Sure, getting the exact piece from another chassis will make replacement easy. Simple trunk area can be reproduced from sheet metal though also, without much difficulty.
Just do some google searching on rust repair and panel replacement. The work your looking to do is stupid simple if you just read up. Do some reading. I don't mean that in a mean way, more of an encouraging way...just read up, you can handle it.
Old Aug 21, 2009 | 01:23 PM
grog's Avatar
Your're lucky its in the trunk because it doesn't need to look perfect (unless you want perfection).
you should also look for the source of the leak that probably caused this and fix it, I would suspect the brake light gaskets or a clogged sunroof drain.
Old Aug 21, 2009 | 02:04 PM
HI91EFHB's Avatar
thanks.
Vagitarian
Paint and Body
Apr 28, 2012 12:44 PM
4g4dcruisin
Paint and Body
Aug 6, 2010 08:57 PM
jokercpc
May 24, 2010 12:08 PM
HiyahBeech!
14
Aug 22, 2007 07:58 PM
baddboy
Sep 22, 2003 09:41 AM
