Rollcage wreck pics!
Old Mar 13, 2009 | 10:32 AM
  #26
Discosteak's Avatar
Default Re: Rollcage wreck pics!
mine did quite well lol combined vehicle speed of about 70 doors still open and close like nothing happened. windshield didnt even break even though it bent both drivers side frame rails pretty bad. front wheel came through the firewall etc. i broke my nose on the cage and my thumb on the steering wheel yada yada. ill actually be reusing the cage in the new car
Old Mar 13, 2009 | 11:14 AM
  #27
Blackcatn2o's Avatar
How do you reuse a roll cage? do you cut it out?
Old Mar 13, 2009 | 01:42 PM
  #28
Discosteak's Avatar
the car in the pic is getting cut apart and the cage will come out as 1 piece.the cage will then be cut up at the welds cleaned up and re welded into the other car
Old Mar 13, 2009 | 01:57 PM
  #29
9KRevLimitDC2's Avatar
J/w did you break your nose on a bar that was covered in padding? (yes i know that wouldn't make that much of a difference) just wondering.
Old Mar 13, 2009 | 01:59 PM
  #30
srmofo's Avatar
I dont know if I would feel secure knowing that my cage has already been in one serious accident....not to mention that the bars are at least tweaked a little bit and they probaly wont fit the same in the new car....I dunno though, let us know how it turns out
Old Mar 13, 2009 | 03:19 PM
  #31
boost4life's Avatar
yeah i def wouldnt recycle a roll cage and you cant get that nhra certified anyway.
Old Mar 13, 2009 | 04:30 PM
  #32
Discosteak's Avatar
SCCA will lol
Old Mar 13, 2009 | 05:37 PM
  #33
bigTom's Avatar
im sorry but that retarted... why wouldnt you just build a new one? a good cage cant just be cut out and put back in that easily...
the more reinforcements the better imo... it also comes down to other things such as customer convienence, cost and what they are trying to get out fo the car. gussets add so much as well. here's one we're in the middle of @ the shop. FWIW i wonder how a roof like this would hold up to the same collision as the first car. I do not see the roof caving in the way it did.
Old Mar 13, 2009 | 09:37 PM
  #34
AbitAvenger's Avatar
damn dan didnt know you wrecked the s13 def a sick cage tho
Old Mar 14, 2009 | 05:32 PM
  #35
96 GSR-T's Avatar
Originally Posted by swapit
heres my boys hatch from loosen it on the street.the cage saved him.
This is my good friends car, I was looking at it while the turbo was still hot. This bar was the first that a guy I know ever installed, just a shelf S&W moly kit and it held up great, obviously this car did not have a full 10pt it was just a 6pt or it would probably look alot better up front.
Old Mar 15, 2009 | 05:21 AM
  #36
mrlegoman's Avatar
Thanks for starting this post! I tried making a post a couple years ago in the road race forum when we where working on the cage design for my EG. I wanted to see wrecked pics to see what worked and what didn't. The mods got all pissy because they didn't want pictures of wrecked cars to act as a deterrent to members of the forum. I'm glad this post hasn't been locked and you haven't been banned...yet.
[EDIT] From an engineering standpoint, I agree with the other users on the guy reusing his role-cage. When a cage goes through a shock like that, you will get micro-fractures all over the place that are not going to be visible with the naked eye. Definitely a bad idea imo.
Old Mar 15, 2009 | 09:02 AM
  #37
rota92
Guest
Posts: n/a
That guy is seriously an idiot if he is re-using the cage, I have no idea why someone would do that after a near death experience.
No money is worth someones life.
Old Mar 15, 2009 | 10:07 AM
  #38
Discosteak's Avatar
nope padding was in the mail i was driving home from work when this happened
the drivers area of the car isnt bent at all if it were i would not use the cage. when the cage comes out of the old car if there is any distortion in the cage i will not use it. i am not reusing a bent cage
Old Mar 15, 2009 | 11:06 AM
  #39
dave@passenger's Avatar
Lol at reusing a cage, future Darwin award winner we can only pray.
Old Mar 15, 2009 | 01:38 PM
  #40
rogueeg6's Avatar
Originally Posted by bigTom
this is sick
Old Mar 15, 2009 | 06:18 PM
  #41
1badascivic's Avatar
all i got to say is wow
Old Mar 15, 2009 | 10:53 PM
  #42
Discosteak's Avatar
Can you explain whats wrong with reusing a cage from a car that was never rolled?
Old Mar 15, 2009 | 11:49 PM
  #43
spectacle's Avatar
Would you reuse a condom?
Old Mar 16, 2009 | 01:29 AM
  #44
Discosteak's Avatar
if i had never put my dick in i wouldn't call it used at all. any one with a braincell want to try and explain my original question? if its that bad i wont do it but i would like someone to explain it
Old Mar 16, 2009 | 04:05 AM
  #45
Aquafina's Avatar
Crush a straight pop can.
Now put a tiny dimple in another can and crush it. Easier huh?
Old Mar 16, 2009 | 06:58 AM
  #46
turboteener's Avatar
Banned
I don't understand why the a-pillar bars were so far away from the A-pillars. I also don't understand why the a-pillar bars weren't tied into the a-pillars with some reinforcement plates.
Old Mar 16, 2009 | 08:30 AM
  #47
mrlegoman's Avatar
It was never rolled, but it was in a hard impact. If the force of the impact tweaked any other part of the cage even an 1/8", then you now have a point of failure similar to the dimple in the coke can example. And as I have mentioned, chances are every weld in that cage is going to have micro-fractures from the force traveling through the chassis during impact. Even if you cut the bars out, grind off the old welds and reweld, the weld point itself is going to still be stressed.
So in the event of another collision, the cage is going to buckle at it's weakest point, which in reused tubing, could be anywhere. Just not worth the risk imo.
I think the other point is, for the time given to cut the cage out, re-prep it and reinstall it, you could just put in a new cage altogether.
I think taking the cage and using it as a template is a great idea. But reinstalling bar stock that has been in a collision just doesn't sit well for most of us.
Old Mar 16, 2009 | 11:04 AM
  #48
slammed_93_hatch's Avatar
roof might not cave in as much but more damage would be done...
That seat is TOUCHING the top hoop, that isn't good in more ways then 1....
Old Mar 16, 2009 | 11:39 AM
  #49
Discosteak's Avatar
Thank you very much after your explanation i will be making a new cage.
Old Mar 16, 2009 | 12:35 PM
  #50
miller's Avatar
Actually the seat isnt its final palce in that pic tom posted, it is about 4" lower then that. That is how the mounting brackets come from sparco and the seat is just rediculously high. We made new brackets that brings the seat to the correct level.
