redoing brake lines? first timer, pointers please!
Old Jun 9, 2007 | 07:16 AM
  #26
Jared's Avatar
yup, those are 10x1.00 banjo adapters to what looks like 3an, then 3an bulkhead fittings at the firewall.
Old Jun 9, 2007 | 09:36 AM
  #27
.RTErnie's Avatar
Default Re: (Jared)
http://www.anplumbing.com ftmfw. Great prices too
Old Jun 20, 2007 | 03:28 PM
  #28
LilCivic04's Avatar
Default Re: brake line tuck? first timer, pointers please! (LilCivic04)
ok so i bought a flaring tool for 60 bucks and i have a problem making the flare straight, its like going to the side. any advise?
Old Jun 21, 2007 | 03:22 AM
  #29
LilCivic04's Avatar
anyone?
Old Jun 21, 2007 | 05:26 AM
  #30
ROTARY's Avatar
what tool are you using to cut the lines?
  #31
LilCivic04's Avatar
Default Re: (ROTARY)
a tube cutter
Old Jun 21, 2007 | 05:36 AM
  #32
ROTARY's Avatar
Ive only seen that happen when the cut is not straight, try putting a little wd-40 inside the tube or on the flaring tool anvil.
Old Jun 21, 2007 | 07:24 AM
  #33
nikolai.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyR &raquo;</TD></TR><TR><TD CLASS="quote">For cutting, you can use your standard tube cutter, but make sure you debur and camfer your ends before flaring.</TD></TR></TABLE>
^^this statement is the solution to your flares coming out uneven. a tubing cutter hardens the metal around the cut making it really difficult to make the flare much less have it come out even. file the tubing down like an extra millimeter after you make the cut. then debur the insides and outsides of the tubing with needle files. its VERY VERY important that the final face of the cut is as flat and striaght as possible before you start making that flare. otherwise your flares will come out lopsided.
Old Jun 21, 2007 | 09:57 AM
  #34
brightside's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i bought a flaring tool for 60 bucks and i have a problem making the flare straight, its like going to the side. any advise?</TD></TR></TABLE>
usually for hard line I use a hacksaw to cut, then a good file to square and smooth the cut out, then a little tapererd reamer to deburr the inside of the tubing. Like one of these here http://www.ares-server.com/Are...14462 Also, you might have the tubing sticking too far out of the holder which might be making the tube flare crooked. for the most part, if the flare is just a LITTLE bit imperfect, you can just tighten that sucker onto the part, and it can fix minor imperfections
Old Jun 22, 2007 | 06:27 AM
  #35
Bakeoff's Avatar
Default Re: brake line tuck? first timer, pointers please! (brightside)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brightside &raquo;</TD></TR><TR><TD CLASS="quote">
you might have the tubing sticking too far out of the holder which might be making the tube flare crooked. </TD></TR></TABLE>
That's the problem I had when I did mine.
Old Jun 22, 2007 | 06:41 AM
  #36
Airbag Club's Avatar
Default Re: brake line tuck? first timer, pointers please! (Bakeoff)
how far out do you recommend the tubing stick out of the holder when trying to flare a tube?
Old Jun 22, 2007 | 07:44 AM
  #37
brightside's Avatar
Default Re: brake line tuck? first timer, pointers please! (ARC Magic)
usually the flare tools come with instructions on how far to stick out the tubing. I think for 45deg double flares (like OEM), its usually the depth of the button tool that squashes the tubing to that diamond shape. kinda hard to explain. on 37deg flare for AN fittings, I usually stick out the tube about .0625"~.125". this should help with the 45deg double flares: http://www.carcraft.com/howto/50919/
Old Jun 22, 2007 | 10:06 AM
  #38
good link, thanks!
chris3385
Mar 25, 2009 11:21 PM
null.
Jun 8, 2007 10:27 PM
LilCivic04
Suspension & Brakes
Jun 7, 2007 08:20 AM
.BigSexy
Apr 8, 2007 05:42 PM
Pandahatch
Welding / Fabrication
36
Feb 17, 2006 01:13 PM
