Problems with my computer after using my tig
Old Feb 2, 2005 | 08:07 AM
essex's Avatar
Default Problems with my computer after using my tig
Is there anyway a tig can cause problems with my computer...as since I started using my tig I have had 2 computers crash in a 4 day period
Could the HF starts cause problems?
Old Feb 2, 2005 | 08:16 AM
civicross's Avatar
Default Re: Problems with my computer after using my tig (essex)
Are they in close proximity? If so, then yes, it could cause the computers for go FUBAR. The electromagnetic power of the welder would be more than enough to mess up the computer.
Old Feb 2, 2005 | 08:39 AM
essex's Avatar
Default Re: Problems with my computer after using my tig (civicross)
The welder is in the basement the comp is on the main floor
I got one computer up and running but the other one refuses to boot
"disk read error, press cntrl alt delete to restart"
Is there anyway to avoid this?
Does elecrtomagnet interference come through the power lines?...sorry I don't know.
Thanks guys.
Old Feb 2, 2005 | 09:16 AM
mopar junkie's Avatar
d'oh... there's no boot sector (or a currupt one). The PC is fine, the boost sector on the hard drive is not. I could probably fix it but I'm probably thousands of miles away. :-P
Hit me with an IM and I'll give you some pointers on how resolve it. As far as preventing it from happening... can't help you there. I know the high-frequency isn't good either. When I'm welding none of the portable phones work either. Pisses my wife off. haha
Old Feb 2, 2005 | 09:43 AM
david@didrace.com's Avatar
Default Re: (mopar junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mopar junkie &raquo;</TD></TR><TR><TD CLASS="quote">d'oh... there's no boot sector (or a currupt one). The PC is fine, the boost sector on the hard drive is not. I could probably fix it but I'm probably thousands of miles away. :-P
I know for Windows 98 " fdisk /mbr " works when you use a boot disk. Not sure if it would work for XP, you might have to use the Recovery Console on a bootable XP CD.
Old Feb 2, 2005 | 11:00 AM
triple_s1x's Avatar
Default Re: (backpurge)
To fix that just run a recovery CD, and at the console you should see a FixBoot somewhere.
Old Feb 2, 2005 | 11:04 AM
ExploitedRacing-HR's Avatar
The welder is in the basement?
Old Feb 2, 2005 | 11:08 AM
essex's Avatar
Thanks guys I'm trying to get it to boot from cd to run the recovery console but it won't even go to any other screen besides the read disk error screen??
Also is this a power surge problem? The computers run off a power bar which is plugged into the wall....is there anyway to stop this from happening when I tig?
Thanks for the replies
Old Feb 2, 2005 | 11:10 AM
essex's Avatar
Default Re: (ExploitedRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">The welder is in the basement?</TD></TR></TABLE>
Yeah...I have a vent fan just for it running to outside....doesn't seem to be a problem, I have no garage and I'm in canada so I'm surrounded by snow...only place left is the basement
Old Feb 2, 2005 | 11:58 AM
as long as theres ventalation your good to go.
Old Feb 2, 2005 | 07:01 PM
xerox445's Avatar
My friend left his cellphone on a welder in his welding class. At the end of the class the cellphone was toast, thing was HELLA messed up.
Old Feb 2, 2005 | 08:17 PM
dornon13's Avatar
Default Re: (xerox445)
is there a floppy in the floppy drive by any chance? if so take it out then try to boot
Old Feb 2, 2005 | 10:32 PM
b16hybridsol's Avatar
Default Re: (dornon13)
everytime i strike an arc my cd player changes songs
Old Feb 3, 2005 | 11:57 AM
project dc2's Avatar
i broke my CD player in my shop. and drained my battery on my phone by leaving it on the table. i tried charging it cuz i went a weekend without chargin. pout the charger and phone on the table all day while i was welding. heheh needless to say. i think it drained it even more.
Old Feb 3, 2005 | 01:08 PM
sleep's Avatar
i weld all day with my portable mp3 player... odd.
accordionfolder
Oct 19, 2009 07:22 AM
HiProfile
Welding / Fabrication
14
Aug 9, 2009 10:54 AM
TurboCoop
Mar 13, 2006 05:19 PM
crookedletterd
Jul 9, 2001 07:49 PM
