pricing on cnc fab?
Old Oct 30, 2008 | 09:21 PM
jbell's Avatar
Default pricing on cnc fab?
i've gotten a few prices on this, and they've varied HUGE.
i'll ask you guys----
custom pulley. about 100mm, 6 and 8 rib next to each other.
aluminum cnc'ed.
Old Oct 31, 2008 | 08:32 PM
blueoval557's Avatar
Default Re: pricing on cnc fab? (jbell)
Is it only one piece? If so, your best finding a small shop, or a guy who has access to a CNC that can do side work on it. Setup is EVERYTHING in the machining world.
Kyle
Old Nov 1, 2008 | 09:22 PM
locash's Avatar
Honestly, I tend to steer away from making one part on my cnc machines. Blueoval is right, setup is everything, and I'd charge a fortune to spend all that time to make one part.
Old Nov 2, 2008 | 09:44 AM
.john.'s Avatar
pricing would probably look something like this:
1 is 500.00
5 is 800.00
25 is 1200.00
100 or more is 25 each
the machine shop i work at is basically about 600 bucks labor for a one off part if it can be completed in one day, then you are just looking at run time after that for each additional part. this is not including material cost or if there is teardown and setup time between part orders.
if you only need one i wouldnt look for a cnc shop. look for an older guy that runs a a manual lathe and can make this in an hour or two off a blueprint. it will be much cheaper than a cnc lathe.
Old Nov 2, 2008 | 04:15 PM
jbell's Avatar
well, after talking to a local fabricator, it seems cnc is overkill.
i need 2 items-
i'd need a plate, about 3/8 thick 17x14- waterjetted. simple shape.
i'd also need a pulley, dual belt, one side ~100mm, one side ~80mm. then bearings pressed in, one on each side.
(similar to this, just one side is 8 rib) http://www.modernperformance.c...l.jpg
scottmeister86
Mar 1, 2011 02:51 PM
weiRtech
Welding / Fabrication
18
Aug 20, 2009 11:19 AM
Die-Laughing
20
Sep 24, 2007 01:17 AM
m3dia_lab
12
Jan 25, 2005 05:20 AM
len
May 5, 2003 09:18 PM
