InlinePro's Headgasket
Old May 4, 2003 | 04:23 PM
len's Avatar
len
Default InlinePro's Headgasket
Does anyone have experience with these headgaskets?
I just want to know if they work. Or does anyone else have a recommendation for one.
I'm looking at the 1mm Headgasket to lower my compression down to 10.3:1. Anyone know where I can get a custom 1.27mm one?
Thanks in advance,
Len
Old May 4, 2003 | 05:51 PM
dfoxengr's Avatar
Default Re: InlinePro's Headgasket (len)
i will be running one on my NA setup, all the inline guys that i knowrun them and all my friends run them, we do work at a local shop though and get discounts though, lol...but theyre excellent, and they can get you a custom size im pretty sure...
Old May 4, 2003 | 06:50 PM
len's Avatar
len
Default Re: InlinePro's Headgasket (hybridvteceg)
If I can get custom sizing that would be great. How is fit and finish? Does it look like something someone put hours on or just made it in a couple seconds. What material is it made out of? Sorry, I'm just **** about these things and want to know what I'm getting myself into before. Oh, I work at a shop too...I think But we fix cars.
Old May 4, 2003 | 06:55 PM
SiRkid's Avatar
there are quite a few running thicker gaskets on stock motors making some nasty power..
they seem to work well(of course if your tuned properly)
Old May 5, 2003 | 07:27 AM
dfoxengr's Avatar
theyre really nice, check their site... http://www.inlinepro.com
Old May 5, 2003 | 09:55 AM
Turbo EG6's Avatar
New User
I ran one on my stock GSR motor with 15psi
Old May 5, 2003 | 12:33 PM
eagle2's Avatar
Default Re: InlinePro's Headgasket (Turbo EG6)
how much hp were u making at 15psi and did u run the car at the track with that boost
Old May 5, 2003 | 01:00 PM
TurboJesse
Guest
Posts: n/a
Default Re: InlinePro's Headgasket (eagle2)
also interested, how did the car hold up at 15psi? HP? times?
Old May 5, 2003 | 05:19 PM
dfoxengr's Avatar
Default Re: InlinePro's Headgasket (Mpir3)
the inline guys and a few of my friends run stock bottom ends on GSRs at 22lbs and 75 shot and hit high 10s...
Old May 5, 2003 | 05:48 PM
speedworks's Avatar
they take a factory 3 piece gasket, take out the center gasket, and replace it with a thick copper gasket. i have used a few. they are very high quality as is all of inlines products.
Old May 5, 2003 | 05:58 PM
evoeone's Avatar
Default Re: InlinePro's Headgasket (speedworks)
ddunno if you honda ac guys do it, but lots of vw people just stack 2 oem gaskets, lowers comp from 10:1 to like 8.8 or 9:1 around there
Old May 5, 2003 | 07:05 PM
Andrew 825SM's Avatar
Default Re: InlinePro's Headgasket (evoeone)
To those people using the gasket, do you ever get a little oil sippage coming from the timing belt area?
Old May 5, 2003 | 07:18 PM
TurboJesse
Guest
Posts: n/a
Default Re: InlinePro's Headgasket (Andrew 825SM)
how long have you guys been running them for? i was considering using one and boosting 7-8 daily on 93 octane and 14-15 at the track on race gas, this is on a b16 with hondata...Think i'll be ok?
Old May 5, 2003 | 07:42 PM
Chrome Pipes's Avatar
I have a 2mm InlinePro gasket for my LS/VTEC. Its really nice quality. I'm in the process of putting the motor back in, once its done I plan to run 15 psi on race gas. I'll let everybody know how it turns out...
Old May 5, 2003 | 09:18 PM
ITR41's Avatar
New User
Default Re: InlinePro's Headgasket (Chrome Pipes)
I am runnin one now 11psi on stock type r bottom end. 230whp 192wtq with a super rich AF ratio.....I have had NO problems at all
eclypzex
Welding / Fabrication
75
Dec 8, 2009 11:59 AM
ShortbusEK
Jan 14, 2008 08:29 AM
Die-Laughing
20
Sep 24, 2007 01:17 AM
turbotime
Dec 1, 2004 02:42 PM
drunknbass
25
Aug 16, 2004 06:57 AM
