Post your best welds!!!!!!!
Old 02-28-2015, 07:55 PM
  #2976
Canuckian
Lugzilla's Avatar
Default Re: Post your best welds!!!!!!!
Originally Posted by Gofastturnleft
These are my orbital welds. Around one inch wide 7/8th deep. All hot wire tig (orbital) takes me 4 passes to weld all the out. Total weld time is about 16 hours straight.
I have the weirdest boner right now
Old 03-01-2015, 07:31 AM
  #2977
HellaFab's Avatar
Originally Posted by turbohatch96y7
Can i get some tips on welding 16 gauge stainless? The thick stuff i can weld no problem. This thin wall is a bitch.
I also have no foot pedal.
The pipe is only 2" . I can get good color on one 1" pass then i think the whole pipe heat soaks pretty fast and the next pass shows too much heat. Do i need to let it cool down for a few minutes?
Torch angle.
I set my amperage and can weld a whole tube with the pedal mashed.
But, If you have any gaps at all with thin wall you're going to have a hard time and it won't look consistent. You shouldn't be able to see light in the joint with a flashlight shining inside the tube.
Old 03-01-2015, 11:19 AM
  #2978
xci_ed6's Avatar
Not the best pic, but:
I made that manifold, who cares how it looked, it worked! I made it out of water pipe (the log) that I welded to the stock manifold head flange (I grind-ed the stock bit off) and a piece of 3/8" steel plate I cut into a turbo flange.
Old 03-01-2015, 06:47 PM
  #2979
SovXietday's Avatar
Uhh... did you not see the thread title? We all care how it looks.
  #2980
Gofastturnleft's Avatar
lol why thank you sir.
Old 03-02-2015, 12:48 PM
  #2981
turbohatch96y7's Avatar
Originally Posted by HellaFab
Torch angle. I set my amperage and can weld a whole tube with the pedal mashed. But, If you have any gaps at all with thin wall you're going to have a hard time and it won't look consistent. You shouldn't be able to see light in the joint with a flashlight shining inside the tube.
I made my charge pipes last night.
I didnt use any filler and got the best color on the welds.
Thanks guys
Old 04-23-2015, 02:54 PM
  #2982
rvs51's Avatar
Thought this turned out nice.
Old 04-23-2015, 03:13 PM
  #2983
I'm really 2slow
2fast4u831's Avatar
^^ Very nice man!!
Some stick welding for a test plate.
Old 05-08-2015, 05:27 PM
  #2984
rvs51's Avatar
Practicing my outside corner joints. Pretty happy with this one.
Then a t4 collector I done today.
Old 05-09-2015, 03:35 PM
  #2985
kingofbattle909's Avatar
HTP?
Old 05-09-2015, 04:15 PM
  #2986
moderator emeritus
98vtec's Avatar
Old 05-10-2015, 11:13 AM
  #2987
rvs51's Avatar
Originally Posted by kingofbattle909
HTP?
Yes. Htp221.
Old 05-10-2015, 10:56 PM
  #2988
FabChild's Avatar
Man I haven't been on here in forever! Usually just post up pics to instagram now. Here is some recent stuff. 321ss corvette parts.
  #2989
FabChild's Avatar
double post!
Old 05-11-2015, 03:14 AM
  #2990
hoochhenry's Avatar
some tasty welds
Old 07-23-2015, 09:17 PM
  #2991
-Intl Steve Krew
Caoboy's Avatar
I know it's not the best welding, but I had a good day today in MIG/GMAW class.
First pic, 5/8", 60* groove weld, 1/4" backing strip. Yes it's shitty. It's my first time welding with NR232... 3G (Vertical.) Instructor was pretty impressed that I was able to weave the gap as well as I did. It's ugly but it worked. He suggested next time running 2 smaller weaves to cap it next time.
The others are 3/16" or 1/4" plate, more dual shield welding, can't remember the specs off the top of my head right now. It was pretty easy to run this flat, especially after running the NR232.
Old 07-30-2015, 02:13 PM
  #2992
rd2smoker's Avatar
A chain tie off and a mother's day gift.
Old 07-30-2015, 05:28 PM
  #2993
-Intl Steve Krew
Caoboy's Avatar
When dat slag peels off doe
Old 07-31-2015, 07:24 AM
  #2994
CODE4's Avatar
English man, English.
Old 07-31-2015, 07:28 AM
  #2995
-Intl Steve Krew
Caoboy's Avatar
The slag peeled up in one piece. I've never had that happen before. *noobstillinweldingclasses*
Old 08-01-2015, 10:13 AM
  #2996
para pat's Avatar
Caoboy,
When running dual shield flux core, unless you are washing out your toes, don't manipulate the gun. It looks like you're trying to do some sort of pause and step pattern like you would with hardwire. On flux core, that's a very easy way to roll slag under the puddle. Keep is smooth, and straight.
edit:
not my work, and pulled off a google image search, but if this person had their machine a little hotter, it would have come out perfect.
http://s2.photobucket.com/user/dfizz...54101.jpg.html
Old 08-01-2015, 11:01 AM
  #2997
-Intl Steve Krew
Caoboy's Avatar
Of which picture are you talking about? The last one I posted?
Old 08-01-2015, 11:11 AM
  #2998
-Intl Steve Krew
Caoboy's Avatar
Do these look better? Same piece as the slag pic. I know it's not 'perfect' but it was my first time running this setup. (I'm taking my first classes)
Old 08-11-2015, 07:07 PM
  #2999
PyroProblem's Avatar
Not mine. I can't weld. But a friend of mine is all into welding and he showed me these. I was amazed that this is even possible and thought you guys might like to see it.
Old 08-25-2015, 12:45 PM
  #3000
rowleym's Avatar
After reading every single post in this thread(took me weeks) along with lots of other Honda-tech stuff, I have finally created an account to say THANK YOU! You guys are great. Such a huge community of knowledgeable people.
Now to ask a question. Which fancy cup should I use? As of the last year I have been using a #8 cup with a standard gas lens on my wp9 flex head torch. I mainly do custom forced induction setups, and a lot of pipe work. My color is pretty good, but not always. I can only weld about an inch at a time.
So, Fupa cup, or toxic cup?
Figured I would ask you guys, as I see the results I'm looking for.
Thank you very much! I will be posting some of my welds soon
Quick Reply: Post your best welds!!!!!!!
