MY CF Project
Old Mar 24, 2006 | 07:31 PM
MikeGRIS's Avatar
Default MY CF Project
Well i have seen a few posts lately, and thought i would post one of my recent projects up. This is my first experiment with some toolmaking gel coat for mold making. I choose a simple part to start, it is just the spark plug cover for our b series engines, I know there are a ton of companies out there that make them, but i was due for some sort of hands on project.
Finish product, not yet mounted but this is where I stopped.
Part out of the mold before trimming
Here is the finish of the part out of the mold
my mold
All in all I think it came out pretty good, The mold has a few spots in the side that need to be patched for future use. But I used some molding clay to patch them for the time being.
This is my second major composites project. I actually built a canoe at school, 15ft : 20lbs. Pretty ill strength to weight ration, you can actually see through the conoe. It is two thin layers of 10oz s glass, with a nomex honeycomb skeleton, and carbon fiber thorts. It was great project, and came out amazing thanks to my teachers help.
Old Mar 24, 2006 | 07:54 PM
lohatch's Avatar
Default Re: MY CF Project (MikeGRIS)
looks real good nice job
Old Mar 24, 2006 | 09:14 PM
crx12's Avatar
Looks pretty good. How thick is your gel coat? I wonder if those trouble spots could be too thin. I had trouble with that once.
Old Mar 25, 2006 | 06:03 AM
MikeGRIS's Avatar
Default Re: MY CF Project (crx12)
I think that is my issue, this was my first time using it, Do you try to apply it in a few layers, like lay one down, let it tack, lay another on top?
Old Mar 25, 2006 | 06:26 AM
Zani's Avatar
i like it
Old Mar 25, 2006 | 06:47 AM
pro547's Avatar
I like it alot... it makes me want to build my molds for my air ducts now.
Old Mar 25, 2006 | 12:11 PM
snoochtodanooch's Avatar
Default Re: (pro547)
very nice job!
congrats
i wouldn't mind seeing a picture of the canoe either
Old Mar 25, 2006 | 03:22 PM
crx12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeGRIS &raquo;</TD></TR><TR><TD CLASS="quote">I think that is my issue, this was my first time using it, Do you try to apply it in a few layers, like lay one down, let it tack, lay another on top?</TD></TR></TABLE>
Yes, on my parts I lay down two coats as you describe. Wait until B stage and drop another layer. B stage meaning when you can touch the corner of the mold and it leaves a print but nothing comes back on your finger. For a mold you could use 3 layers of resin for the gel coat. 1mm is probably as thin as you want to go with a gel on a mold. Of course this might vary with the type you are using but thats a good start. If you are spraying it on you should be able to drop 1mm thickness with the right gun and tip but I am assuming you are brushing it on?
Old Mar 27, 2006 | 05:40 AM
MikeGRIS's Avatar
Yeah I am brushing it on for now. Down the road if i get more into mold making i will spray it on.
By the way your site is great, added it to my list and look forward to reading and learning more about the process.
Where is a good place to buy a vacumn pump? i think want to do some infusion.
The canoe is up for the winter but i will snap a photo of is soon.
Old Mar 27, 2006 | 06:28 AM
carbonall's Avatar
* B A N N E D *
Very nice! Good job on your project!
Old Mar 27, 2006 | 06:43 AM
_Keith_'s Avatar
Make some for the ls motor.... lol nobody does that
Old Mar 27, 2006 | 06:53 AM
underpressure02's Avatar
Looks good man. Lets see some pics of canoe
mark_JDM
Sep 17, 2005 10:22 AM
hungsteR
Nov 17, 2002 07:38 PM
ITRinEJ1
May 2, 2002 10:27 AM
ITRinEJ1
May 2, 2002 10:20 AM
B2FiNiTY
May 1, 2002 11:11 PM
