miller 180SD or the 200SD
Old Apr 11, 2006 | 11:58 AM
Quickgti1.8t's Avatar
Default miller 180SD or the 200SD
Heys guys im looking for a tig, i have really never tig'd so i'd like to start. I have mig welded. But im looking into doing alumium. It will be mostly for garage use. I dont want to spend too much i just need a pretty good aluminum and stainless welder
Old Apr 11, 2006 | 12:03 PM
k24em2's Avatar
Default Re: miller 180SD or the 200SD (Quickgti1.8t)
Sync 200. They don't make the 180 anymore.
Old Apr 11, 2006 | 12:05 PM
Default Re: miller 180SD or the 200SD (k24em2)
hmm on the cornwell truck he said he has a 180SD and can't get a 200SD I went to local welding supply and they had a 200SD for 1940 with the runner package
Old Apr 11, 2006 | 12:25 PM
weiRtech's Avatar
OG Fabricator
i have a 180sd, it is fine. they didn't have the 200 when i bought mine, if they had i would have gotten the 200 for sure- you can run a watercooled torch on it i believe.
Old Apr 11, 2006 | 12:52 PM
TurboJesse
Guest
Posts: n/a
Default Re: (weiRtech)
I have a dynasty and a 200sd...The new 200 has some features the older 180's didn't have,...pulse, etc
Old Apr 11, 2006 | 06:31 PM
19civic93's Avatar
Default Re: (TurboJesse)
the 200sd replaced the 180sd but you can still buy the 180sd's while supplies last.
Old Apr 12, 2006 | 12:57 AM
AspectIndustries's Avatar
Default Re: (19civic93)
Go with the syncro200, its just a little more. Unless you can find a 180SD for cheap.
Check for http://www.airgas.com They have reasonable prices actually, compared to 4-5 welding suppies stores around my area. They are a nation wide company, if you want it locally. I had good experience with them, other dont. Most can match any online prices to, only that uncle sams a b!tCh.
Old Apr 12, 2006 | 01:50 AM
Lamchop0000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">you can run a watercooled torch on it i believe.</TD></TR></TABLE>
FYI. it doesnt come with a watercooler.
any tig welder can run a watercooled torch with the proper equipment
Old Apr 12, 2006 | 05:13 AM
Fred Allen Burge's Avatar
Default Re: (Lam.N)
I have the 180SD, bought it used from a member here and I'm very happy with it. I have only used it for aluminum so far and it seems to be just fine for that. I too just wanted a cheap(ish) welder to use in the garage for intake manifolds, IC pipes, brackets and later some stainless/mild steel exhaust manifolds.
Fred
Old Apr 12, 2006 | 06:29 AM
Moto-C's Avatar
B A N N E D
we had a 180 for about 8 months. once the 200 was released we immediately upgraded to that unit. im hoping to purchase a 350 in the near future once i gather the funds and keep the 200 for low amperage duty.
Old Apr 12, 2006 | 08:33 AM
blackwagon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t &raquo;</TD></TR><TR><TD CLASS="quote">hmm on the cornwell truck he said he has a 180SD and can't get a 200SD I went to local welding supply and they had a 200SD for 1940 with the runner package</TD></TR></TABLE>
Because he wants to sell the "outdated" 180
JDM-sol 89
Welding / Fabrication
Sep 20, 2011 06:32 PM
YZFR6
11
Nov 26, 2009 05:13 PM
locash
Aug 2, 2007 05:41 PM
BANNED_ID
Oct 20, 2005 08:06 AM
JOeeeee y0
Apr 6, 2005 07:36 AM
