Merge Collector Fabrication 101
Old 08-23-2011, 03:14 PM
  #51
Race Egr's Avatar
Default Re: Merge Collector Fabrication 101
Ahhh, I was bored so I modeled this up real quick. I think I am gonna make some templates from it and play with different angles.
Old 09-22-2011, 10:02 AM
  #52
igorka_91's Avatar
Thank you for making this write up. This will help me out a lot once i will be building my B series turbo manifold.
Old 09-25-2011, 04:59 PM
  #53
SQ is the SQUAD's Avatar
subscribed and bookmarked
Old 09-28-2011, 01:43 PM
  #54
SpeedwayCoating's Avatar
This is a great writeup. Thanks for the info!
Old 04-05-2012, 03:21 PM
  #55
|CL|NIKI's Avatar
It is:
60 deg. (or 30 his way) for 3 in 1
45 deg. for 4 in 1
36 deg. (or 54 his way) for 5 in 1
30 deg. (or 60 his way) for 6 in 1
If You make 0 (or I ) mark on the tubes, then rotate for example 45 deg. - cut, then back to 0 ( I ) mark turn -45 deg. and cut again.
Cheers mate's.
Old 07-25-2012, 07:46 PM
  #56
Tyconway's Avatar
Originally Posted by 9bells
Carbide tipped blades exhibit no walk in any application, high speed or low.
Every experienced any problems with it catching or hanging up? I've used them doing normal cuts on tubing, just scared to use mine for cutting collectors due to the cost of the blade.
Old 08-13-2012, 01:43 PM
  #57
djuosnteisn's Avatar
Nice jig OP. I think i'll make a similar one this weekend.
What's the preferred method for making a wastegate hole in the collector? Sched 10-40 stainless isn't exactly easy to work with... haha. When i built my last manifold, i just accepted the painstaking task of hogging out a hole. But now that i want to build another, i would like to learn the right method. Plasma cuter?
Old 08-13-2012, 08:18 PM
  #58
TannerS14's Avatar
You could plasma to get it close and then die grind. But really you need a mill in order to hole saw out an uneven surface like that. As you might have figured out, a drill press will skip all over the place. With a mill you can have one side of the hole saw on the collector etc and it still stays smooth.
Old 08-14-2012, 07:59 AM
  #59
Plasma's are much cheaper than mills, hahaha. Looks like i'll be taking the low road for a while.
Old 08-14-2012, 11:45 AM
  #60
zuptidi's Avatar
wanted to ask for a All motor car, Would a smaller angle help yield more power??
Usually collectors are made with a 12-20 degree, anyone ever tried doing a 7 or 8 degree one??
Old 08-15-2012, 02:59 AM
  #61
that-guy's Avatar
7 or 8 degrees would put them so close together that they would be extremely difficult to weld. i highly doubt that the aggrivation of attempting to weld that wouldn't be worth the extremely slim chance you actually gain any power from it
Old 08-15-2012, 11:16 AM
  #62
ImAcracker's Avatar
I remember a long time ago when my manifold was being made my friend had me drill the hole for the waste gate. He gave me a hand drill and a hole saw and told me to just go slow. It worked surprisingly well.
Old 08-15-2012, 12:02 PM
  #63
h22crxpwr's Avatar
Nice Write up!!! Wow taking the time to write that out is pretty cool of you..
Can't wait to try and make one...
Old 08-20-2012, 09:56 AM
  #64
manifoldmiketyson's Avatar
Great write up. If you're cutting a bunch of different heights, angles and configs, i usually model the collector, create some cut jigs, cut with a angle grinder and sand them down. i skipped a couple steps in the pics, but you should get the jist. usually about 4hrs from start to finish. i use a 4.5" angle grinder, sharpies, 6x48 belt sander and the expensive ceramic belts.
Old 02-26-2013, 08:08 PM
  #65
1QwIkEf's Avatar
Location: R.I.P Brian Arbogast...you will be missed, maryland, USA
good info in this thread
Old 03-08-2013, 06:22 PM
  #66
thermal's Avatar
very nice post!
Old 08-08-2013, 10:43 PM
  #67
cheezeball's Avatar
Great post! I still have a question though.
Looking at the models I have made and the last photo posted, even after the last cut, the end of the merge is not round, so how does one get it to seal against the single pipe that connects to it? That is not shown. Do you weld it up and use an expander/swager to open it/round the merge before welding it to the single outlet pipe or somehow flatten the outlet pipe? (a 2 in 1 would be wider than it is tall unlike a 4 in 1 which would at least be sort of square). ?????
Thanks!
Old 08-23-2013, 11:00 PM
  #68
opc
opc's Avatar
you explained this very well!!!
Old 12-12-2017, 02:44 AM
  #69
Bgbmxer's Avatar
Anyone else not able to see the original posters pictures?
Old 08-25-2018, 09:02 PM
  #70
Tpotts00's Avatar
Awesome write up!
Old 09-18-2018, 02:35 PM
  #71
brettak 2008's Avatar
This is an excellent article, but I can't now receive the pictures. Any advice?
Old 11-17-2020, 10:31 AM
  #72
Bez_Vanquish's Avatar
Why can't i see any pictures?.. write up looks great but the pictures to go with it would be a bit better haha. Anybody know why i can't see the pics?..
Old 06-15-2022, 03:11 AM
  #73
STUKIN97's Avatar
I have the tooling, angle cut jig, band saw, Purge block & Tig welder. But I have yet to try. I did some test cuts with PVC which is good cheap practice for getting the angle cuts where you want
angrysmileyface
06-22-2014 04:00 AM
.:cesar:. ELUSIVESIR
UK and Europe Regional
19
05-15-2012 01:25 PM
Chimera
08-30-2005 09:49 AM
Veritas-Aequitas
Honda Motorcycles
32
08-20-2005 04:33 PM
rs-sex
11-12-2002 02:16 PM
Quick Reply: Merge Collector Fabrication 101
