MasterCam or SurfCam what are the differences?
Old Aug 12, 2004 | 07:22 AM
Spade's Avatar
Default MasterCam or SurfCam what are the differences?
CNC software.
I'm planning on getting certified in both programs however, I was wondering what's the difference between the two and which is used more often?
Signed up for the basic MasterCam, CNC setup and operation, and Machine tools (basic toying with fabrication) for this semster.
Old Aug 12, 2004 | 12:09 PM
eg92b16a2's Avatar
Default Re: MasterCam or SurfCam what are the differences? (Spade)
They are both the same in respect that they use surfaces and lines to create toolpath. I have used both and I prefer surfcam more bc I used it more. But MasterCam is used much more in the world. But Surfcam has a really good modeler that is similar to SolidWorks. I haven't use them systmes since 2001 so they might have change a lot.
Now I use ProE and loving it. It also uses line and surfaces but can recognize solids too and regen toolpaths if existing part has been modified. You don't have to create the new toolpath for the changes. Just push the regen button and new toolpath is created.
After you learn MasterCam you will be able to learn other CAM software. They all have the same procedure but just different steps to get to the end result.
Old Aug 12, 2004 | 04:42 PM
NCchris's Avatar
MasterCam and Surfcam are kinda like AutoCad, there both good basic packages with very broad usage. Has nice features as does other *.Cam packages. They all compete in the same marketplace so they have to offer at least as much as brand x. Both of these packages have been around forever. We use Gibbs at work, a little above the basic packages. Mostly because of it's solids recognition. Our work is aerospace, we have to manipulate files from Pro E, Unigraphics, and other "High End" cad packages that the aerospace designers use.
As far as knowledge, go for it, all the stuff works similarly. If you are planning on a design/CNC programming career, get some basic machining/fab knowledge as well. To rise above the "button pushers" you will need to know more than what you can do with a computer.
HTH
chris
Old Aug 12, 2004 | 05:39 PM
Spade's Avatar
Default Re: MasterCam or SurfCam what are the differences? (NCchris)
Thanks guys.
For the "machine technology II" certification, I not only am doing CNC but, welding and other machining tools as well. I'm only concentrating on CNC this semster because the way the classes worked with my time schedule
I hope to get to the MIG/TIG next semester.
oryanh
May 22, 2003 10:01 AM
Stewie
Oct 18, 2002 05:49 PM
