Hood with an angle
Old Aug 30, 2008 | 09:13 PM
  #26
KNS Autosport's Avatar
Laugh all you want but I have done some tests and it helps keeping the engine bay cooler by average 15 degrees.
Old Aug 31, 2008 | 10:16 AM
  #27
Project.09's Avatar
Default Re: (KNS Autosport)
Fahrenheit or Celsius?
And do you run on a turbo or na?
Thanks for the info!
Old Aug 31, 2008 | 12:13 PM
  #28
NIGHTRIDER27's Avatar
Default Re:
it makes my car look stupid, but it works, it has reduced the under hood temp, especially in the summer you can open the hood and not get blasted with hot air.
Old Sep 1, 2008 | 03:41 AM
  #29
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KNS Autosport &raquo;</TD></TR><TR><TD CLASS="quote">Laugh all you want but I have done some tests and it helps keeping the engine bay cooler by average 15 degrees.
Where did you put the sensor to measure this?
Old Sep 1, 2008 | 05:41 PM
  #30
PTPbracket's Avatar
I did this on a car and went to a local skate shop an bought doh-doh bushings from skateboard trucks.
used the bigger ones for the rear and the smaller ones for the front. Looked sick when you look up close.
Old Sep 1, 2008 | 05:55 PM
  #31
DFW's Avatar
DFW
Default Re: (PTPbracket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
Where did you put the sensor to measure this?</TD></TR></TABLE>
x2...I still want to see actual data...looks too stupid to just think it works.
Old Sep 2, 2008 | 09:56 AM
  #32
splitime's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">
x2...I still want to see actual data...looks too stupid to just think it works.</TD></TR></TABLE>
I have one simple test performed a few winters ago. With hood propped I couldn't get the car up to temp. With hood as it is from factory... warmup in minutes.
No data... but the lack of ability to get car upto temp played into it.
This was on a stuck thermostat car also btw... but the comparison is still valid.
Old Sep 2, 2008 | 10:03 AM
  #33
DFW's Avatar
DFW
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
This was on a stuck thermostat car also btw... but the comparison is still valid. </TD></TR></TABLE>
Was that at an idle or with driving? You must have some hard winters
Old Sep 2, 2008 | 10:12 AM
  #34
splitime's Avatar
Default Re: (DFW)
Was that at an idle or with driving? You must have some hard winters </TD></TR></TABLE>
Thats driving around. Was one day and then next, same temps... cold . Simple hop in car, start it up... drive outta garage and head to work.
Old Sep 2, 2008 | 12:14 PM
  #35
DFW's Avatar
DFW
Thats driving around. Was one day and then next, same temps... cold . Simple hop in car, start it up... drive outta garage and head to work.</TD></TR></TABLE>
Haha, kind of glad I live in Texas, winters aren't bad
Old Sep 5, 2008 | 11:22 AM
  #36
wolve's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project.09 &raquo;</TD></TR><TR><TD CLASS="quote">their are a lot of people who say diffirent things
I spoke to one guy (itr) that said it brought a diffrence of 15% (he messured it)
and then one on the ek9 forum how said that his temperature rises..
so am like the hell.. am going to try it myself.. the only way to find out for sure</TD></TR></TABLE>
trust me, you won't be the only one in holland
ik rij al een klein jaartje zo rond
it all started when my ragged old d15 radiator could not keep up with my bseries swap.
after the hood pop my cooling problem got better but the best increase i saw in my intake temps. only 0-5 degrees warmer then ambient temp at WOT at about 60-100-125-150+ mph
that is with a Warm Air Intake.
it works alright
Old Sep 7, 2008 | 09:34 AM
  #37
921lsturbo's Avatar
just use the covers that come on ngk spark plugs cut them to size thats what my buddy with a 240 did
Old Sep 7, 2008 | 01:14 PM
  #38
blaak-crx's Avatar
Default Re: (921lsturbo)
There made of cardboard, so when it rains, it will get mushy.
Old Sep 7, 2008 | 05:19 PM
  #39
Kevin's Avatar
Default Re: (blaak-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaak-crx &raquo;</TD></TR><TR><TD CLASS="quote">There made of cardboard, so when it rains, it will get mushy.</TD></TR></TABLE>
Some are made of plastic.
Old Sep 8, 2008 | 08:20 AM
  #40
HiProfile's Avatar
Default Re: (DFW)
Check in the F.I. forum. Someone with major heat issues was trying different things, this being one of them. It did get his ECT's down 10-15F, which can mean a lot if you really are pushing your cooling system.
Then he took a junk hood, cut a gap/hole in the front like on the EVO's, and it helped a LOT more than just the washers.
IMO if you don't have a turbo, there's no reason to do this besides looks. I don't think it looks all that great. What I find funny is the same people who do this will regularly flag vented hoods as 'rice', despite it being the last resort to someone's 400whp turbo-related cooling issues.
Old Sep 8, 2008 | 08:52 PM
  #41
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: (Project.09)
Heres the link to the engine bay ventilation discussion. If you read thru it you'll find that there was definitely some decrease in bay temps from venting your engine bay.
https://honda-tech.com/zerothread?id=2352358
As far as it being a fad, yes some took it too far but seriously 5$ in hardware to prop the hood and decrease bay temps and chance of heat soak is better than spending $500+ on an even uglier vented hood which are so common
Dont forget to remove the seal along the upper cowl. You wont need to prop the hood as high with it removed making it very slightly angled. GL
Old Sep 13, 2008 | 04:58 PM
  #42
h22ej8's Avatar
Lol you guys are idiots using washers to 'rake' your hood.
Look into steel spacers... far better idea.
Old Sep 14, 2008 | 12:17 AM
  #43
9295EJ-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PTPbracket &raquo;</TD></TR><TR><TD CLASS="quote">I did this on a car and went to a local skate shop an bought doh-doh bushings from skateboard trucks.
used the bigger ones for the rear and the smaller ones for the front. Looked sick when you look up close.</TD></TR></TABLE>
thats a really good f*ckin idea! i am a skateboarder of 10 years, and i never thought of that! my washers are getting replaced with some shorty's doh dohs! asap!
Old Sep 15, 2008 | 08:56 AM
  #44
Default Re: (h22ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22ej8 &raquo;</TD></TR><TR><TD CLASS="quote">
Look into steel spacers... far better idea.</TD></TR></TABLE>
Exactly what i use, with upgraded strength bolts as well
Old Sep 16, 2008 | 12:21 PM
  #45
kidkombo's Avatar
i use retainers...4 on each side...i have to do it because the hood will not close with the damn rbc manifold..
Old Sep 17, 2008 | 07:02 AM
  #46
srmofo's Avatar
Default Re: (Mugencrxsir1)
ya know my DVOM has a temp probe that I have never used....once I get the car back on the road I might do a little write up on it.... some before and after temps, hell it'll only take 10 minutes to install the washers and my car already looks like **** from all the salt and ice here in ohio, so what the [freak] do I care
Old Sep 17, 2008 | 09:08 AM
  #47
ExVtec's Avatar
Default Re: (srmofo)
Just pull the weather stripping out of the back between the hood and the firewall.
Does hte same thing and doesn't look gay.
Old Sep 17, 2008 | 11:26 AM
  #48
Default Re: (ExVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">Just pull the weather stripping out of the back between the hood and the firewall.
I do that also but honestly i doubt that would make much of a difference just by itself. Your talkin really only a 1/4" gap you would create doing that. Sure it would help some but might as well space it if your fighting heat soak due to high bay temps.
Old Sep 17, 2008 | 09:39 PM
  #49
rotten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">Besides performance from ventilation </TD></TR></TABLE>
I seem to recall that Real Time Acura did back to back tests and found that the spaced-up hood actually hurt cooling performance.
When we were having cooling issues on the Integra rally car, it did not seem to help any. So any supposed cooling performance is going to be be negligible or perhaps in the wrong direction
Old Sep 18, 2008 | 01:05 AM
  #50
wolve's Avatar
Default Re: (rotten)
strange, it worked for both my civic with cooling problems, track BMW and my BMW 325 with broken coolingfanclutch
