Difference between MIG and TIG
Old Oct 7, 2004 | 08:38 PM
JDM Factor's Avatar
Default Difference between MIG and TIG
It's a pretty noob question but I'd like to know what the difference is.
Old Oct 8, 2004 | 07:38 AM
Doctor CorteZ's Avatar
Default Re: Difference between MIG and TIG (JDM Factor)
these answers are easily found doing a search.
Old Oct 8, 2004 | 02:10 PM
zer0bot's Avatar
Default Re: Difference between MIG and TIG (Doctor CorteZ)
https://honda-tech.com/zerothread?id=958847
Old Oct 8, 2004 | 06:56 PM
HamiltonRex's Avatar
Default Re: Difference between MIG and TIG (zer0bot)
Mig = GMAW (gas metal arc welding) Tig = GTAW (gas tungsten arc welding)
Tig is more controlled in everyway possible, requires more skill, and is slower, and more versatile. Weld anything from carbon steel to titanium. Also less strength.
Mig is less controlled, faster welding, easier. Less versatile. Most widly used on carbon steels.
I could go into SOO much detail, thats just the basics.
Old Oct 9, 2004 | 10:40 AM
Stoich EG2's Avatar
Default Re: Difference between MIG and TIG (HamiltonRex)
can you weld suspension parts together? such as a strut bar with a MIG welder? would it be strong enough? i have a snap on MIG welder and i wanna do some custom fabbing
Old Oct 9, 2004 | 04:16 PM
Default Re: Difference between MIG and TIG (Advan06)
sure you can weld it, if your good enough.
Old Oct 9, 2004 | 06:50 PM
MyVtec8yourV8's Avatar
Someone said you got to weld in a certain direction. what direction or pattern do you make while your mig welding... i bought a 90amp mig welder befor i knew anything.. now i want to get rid of it and get a mig welder with gas instead of rosin core... the welds look ugly as hell..
Old Oct 11, 2004 | 02:41 AM
Goullish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Tig is more controlled in everyway possible, requires more skill, and is slower, and more versatile. Weld anything from carbon steel to titanium. Also less strength.</TD></TR></TABLE>
You mean more strength.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyVtec8yourV8 &raquo;</TD></TR><TR><TD CLASS="quote">Someone said you got to weld in a certain direction. what direction or pattern do you make while your mig welding... </TD></TR></TABLE>
They were probably talking about the angle your welding at. You want to push the bead, and change your angle to get the best penetration.
Old Oct 11, 2004 | 06:11 AM
Default Re: Difference between MIG and TIG (Goullish)
Thats what I thought i was welding and constantly moving the arc.. cause i was burnign threw the exaust.(practice peice) so what angle is best?
Gustav129
Welding / Fabrication
18
Jan 27, 2013 07:17 PM
Flashmn
Dec 26, 2006 07:29 AM
LostCRX
10
Nov 3, 2004 11:21 AM
Green Street
10
Dec 31, 2003 02:40 PM
SHystrdyGSRtdy
Apr 11, 2003 08:28 PM
