Came across this thread on vwvortex, some guy selling out his machine shop.
MODS if you want to delete this or move it feel free. I thought I would post in here since most of the people in this forum may use some of these machines. It is not my sale, don't even know the guy just thought I would pass on the info.
http://forums.vwvortex.com/zerothread?id=1791732
Re: Came across this thread on vwvortex, some guy selling out his machine shop. (Dan GSR)
i sent the guy a pm and asked him for some contact info.
He got back to me. here is his email address
eriksmachining@yahoo.com
Modified by underpressure02 at 3:39 PM 1/24/2005
Re: Came across this thread on vwvortex, some guy selling out his machine shop. (underpressure02)
i am the guy with the shop i thank you for placing the thread. if any body is interested email me you address at eriksmachining@yahoo.com and i can send you the list .
Thankyou for your time Erik Hustedt
what up eric... i just wanted to say he's a good guy with some good stuff... nobody should have any qualms about buying something from him
OG Fabricator
Re: Came across this thread on vwvortex, some guy selling out his machine shop. (eriksmachining)
You guys need to keep in mind that just because an item needs 3 phase power, it doesn't mean that you simply can't use it at home. If you're good with electronics, you can build a converter for about $100 or less if you can find "donated" stuff... and you can buy a nice 5hp rotary phase converter for $400+, sometimes less on ebay. A 5hp RPC will run almost any 3hp 3ph motor, and even can run a couple smaller ones at the same time.
I don't want to divert this thread, but wanted you all to know that 3phase is possible at home, but it will cost you a little for the converter. The actual cost of running it isn't much at all really.
Re: Came across this thread on vwvortex, some guy selling out his machine shop. (Engloid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid »</TD></TR><TR><TD CLASS="quote">You guys need to keep in mind that just because an item needs 3 phase power, it doesn't mean that you simply can't use it at home. If you're good with electronics, you can build a converter for about $100 or less if you can find "donated" stuff... and you can buy a nice 5hp rotary phase converter for $400+, sometimes less on ebay. A 5hp RPC will run almost any 3hp 3ph motor, and even can run a couple smaller ones at the same time.
I don't want to divert this thread, but wanted you all to know that 3phase is possible at home, but it will cost you a little for the converter. The actual cost of running it isn't much at all really. </TD></TR></TABLE>
You sure are knowledgeable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eriksmachining »</TD></TR><TR><TD CLASS="quote">come on people i got a lot of good stuff </TD></TR></TABLE>
post the list
post the list
OG Fabricator
Re: Came across this thread on vwvortex, some guy selling out his machine shop. (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist »</TD></TR><TR><TD CLASS="quote">
You sure are knowledgeable </TD></TR></TABLE>
Dude...I was the one that told Gore how to invent the internet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eriksmachining »</TD></TR><TR><TD CLASS="quote">its kindof big not sure how to do it either</TD></TR></TABLE>
courtesy of engloid via another forum
3 Milling Machine w/Support Tooling
$ 5,400.00
5 Lathe w/Support Tooling
$ 6,000.00
w/all
7 Band Saw w/Blades
$ 2,000.00
w/all
9 Drill Press w/Chuck
$ 800.00
10
11 Surface Grinder w/multiple extra wheels
$ 1,000.00
12
13 Belt Sander w/Belts
$ 1,400.00
14
15 Cold Saw w/Blades
$ 2,500.00
16
17 Tapping Press Size #1 w/Collets
$ 350.00
18
19 Big Blue Drill Press
$ 350.00
20
21 Ring Roller 18" Wide w/spare rollers
$ 1,500.00
22
23 Box Brake (36) w/16 ga. Capacity
$ 1,000.00
24
25 Finger Brake (24) w/16 ga. Capacity
$ 500.00
26
27 Turret Press w/Punches (Random Assortment)
$ 500.00
28
29 Hydraulic Table w/2000 lb. Capacity
$ 1,000.00
30
31
32 15 Drawer Lyon
$ 1,000.00
33 Contents:
34 Large Assortment of End Mills
35 Horozontal Milling Cutters
$ 500.00
36
37 Precision Fixtures:
38 Rotary Table
$ 800.00
39
40 Angle Plates Varying Sizes
41 Clean
$ 75.00
each
42 Older
$ 30.00
each
43
44 12" x 18" Precision Inspection Table (Surface Plate)
$ 200.00
45
46 Various Vices
47
48 Collet Fixtures (Simplex)
$ 75.00
each
49
50 1" Steel Top Workbench (4' x 6')
$ 500.00
51
52
53
54 Hardware and Maintence Items:
55 (2) 1 Large, 1 Small Diameter O-Ring Kits
56 Grease Fitting Kit
57 Large Variety Pneumatic Fittings
58 Standard Grade 8 Nuts and Bolts
59 Standard Grade Regular Nuts and Bolts
60
61 Barstock:
62 10' and up Steel and Aluminum (Round, Square, and Rectangle)
63 10' and under Steel and Aluminum (Round, Square, and Rectangle)
64
65 Etc.:
66 Assortment of DC and AC Electrical Motors
67 Electrical Parts - Plugs, Wires, Switches, etc.
68 3 Filing Cabinets (2 - 3 drawer, 1 6 drawer)
69 Steel Shelving
$ 5,400.00
$ 6,000.00
w/all
7 Band Saw w/Blades
$ 2,000.00
w/all
$ 800.00
10
$ 1,000.00
12
$ 1,400.00
14
$ 2,500.00
16
$ 350.00
18
$ 350.00
20
$ 1,500.00
22
$ 1,000.00
24
$ 500.00
26
$ 500.00
28
$ 1,000.00
30
31
32 15 Drawer Lyon
$ 1,000.00
33 Contents:
$ 500.00
36
38 Rotary Table
$ 800.00
39
41 Clean
$ 75.00
each
42 Older
$ 30.00
each
43
$ 200.00
45
46 Various Vices
47
$ 75.00
each
49
$ 500.00
51
52
53
60
61 Barstock:
64
65 Etc.:
69 Steel Shelving
If there are any local(western suffolk) paying trash picers I got loads drop me a line.
Isaac
10-23-2001 02:45 PM
