anyone good with solid works?
Old Jun 27, 2008 | 06:40 PM
gtconcepts's Avatar
Default anyone good with solid works?
Im building some headers prototypes in solidworks everything is all good unitl I get to the collector part , I build the collector but for some reason the last assembly is not perfect I cut each tube at 90 degres 2 cuts per tube but when I assamble them one is off is not coincident is actually a bit bigger If anyone can help me out I can send u my drwaing so u can see what im talking about..
thanks
Gil
Old Jun 27, 2008 | 06:44 PM
k24em2's Avatar
Default Re: anyone good with solid works? (gtconcepts)
Yea I can take a look at it.
Old Jun 27, 2008 | 07:05 PM
gtconcepts's Avatar
Default Re: anyone good with solid works? (k24em2)
Cool bro , Pm me your email so I can send u the file
Thanks
Old Jun 28, 2008 | 06:57 AM
FST GSR 1's Avatar
I could also look at it as well if needed.
Old Jun 28, 2008 | 08:33 AM
DDEVIANT1's Avatar
Default Re: (FST GSR 1)
Me too, I am pretty handy with SW, although I mostly do wheel designing.
Old Jul 3, 2008 | 04:41 PM
teefunk01's Avatar
Default Re: (DDEVIANT1)
I am proficient in solidworks as well pm me if you still need help
Old Jul 7, 2008 | 06:32 PM
MY_EL_1's Avatar
Default Re: (teefunk01)
I am using Unigraphics but i'd still like to take a look, Please.
Old Jul 8, 2008 | 06:39 PM
91TSiGuy's Avatar
Default Re: (MY_EL_1)
I had a similar problem with this, but with actually cutting a collector in real life. You're probably spinning the tube 90* using it's center line as the point of radius. What's happening is since the tube is going to be angled (say 15*-30*) at the merge, you need to take that into consideration. Draw a line that'll be parallel to the turbo flange through your first cut. Then, while looking at the tube from the end (you'll be seeing it as an "O" in a sense), you'll want to make that newly drawn line horizontal on the screen, and then draw a line perpendicular to that which will be your "blade cut" basically.
__
__/_/___
| /_/
| O
Sorry, that's my poor excuse of a drawing for what I tried explaining above. Looks like the top lines shifted left. doh.
Old Jul 9, 2008 | 02:57 PM
gtconcepts's Avatar
Default Re: (91TSiGuy)
Thanks bro , I will give it a try
b00st4life
Welding / Fabrication
May 9, 2012 07:07 PM
SovXietday
24
Jul 30, 2011 01:35 AM
ACTION JACTION
Jul 6, 2011 07:26 PM
Falconzfan0101
Jul 16, 2010 09:22 AM
ITR-EKcoupe
Oct 16, 2009 01:55 AM
