Additive to keep tumbler from rusting
Old 01-23-2012, 08:20 AM
turbojeesx's Avatar
Default Additive to keep tumbler from rusting
For those of you that use a tumbler, what type of additive are you using to keep the interior of the tumbler from rusting? I've used some soapy water and it works great, but is slowly rusting the inside of the tumbler along with the outer portion of the cage.
Old 01-23-2012, 04:47 PM
k24em2's Avatar
Default Re: Additive to keep tumbler from rusting
what kind of tumbler do you have? we use machine coolant like a cnc machine
Old 01-23-2012, 04:50 PM
PRLdrag240's Avatar
Sodium nitrite and physan 20. We use this in our plasma table. Good homemade plasma quench
Old 01-25-2012, 02:09 PM
c5R
c5R's Avatar
wd40 as a cutting agent and rust preventative
Old 01-26-2012, 06:18 AM
turbojeesx's Avatar
I'm using a qwick-way tumbler. It's going to take probably 5 gallons of liquid to get it up to height for the cage to splash through it--trying to keep it this on the cheap as I'm sure it'll be $$$ to change when it gets dirty.
Old 01-26-2012, 05:10 PM
k24em2's Avatar
I'd recommend calling the company that made the tumbler and ask them if they have a recommendation....barring that call enco or msc or one of the industrial supply houses and see what their tech support recommends for something inexpensive.
Old 01-26-2012, 05:40 PM
OG Fabricator
SLMachine's Avatar
I assume this isn't a bowl/tank style tumbler? The compound fluids i use here have rust inhibitors in them.
Old 01-27-2012, 05:12 AM
turbojeesx's Avatar
It's a basket style very similar to this:
http://www.jamisonequipment.com/picP...ytumbler-1.gif
96supercharged
Welding / Fabrication
36
01-23-2008 02:17 PM
portaman03
05-13-2007 06:41 PM
xdjoynerx
08-08-2004 10:36 PM
JLange
02-21-2003 05:42 AM
ebelp
08-21-2002 01:01 PM
Quick Reply: Additive to keep tumbler from rusting
