Adapting 1000RR cluster?
Old Aug 26, 2008 | 05:15 PM
Justin Olson's Avatar
Default Adapting 1000RR cluster?
Anyone in here adapter motorcycle clusters for use in their project car? I'm interested in giving this a shot. I really like the look off the 1000rr cluster:
Old Aug 26, 2008 | 05:30 PM
k24em2's Avatar
Default Re: Adapting 1000RR cluster? (Justin Olson)
Have you thought about the stack gauges?
Old Aug 26, 2008 | 06:52 PM
Smokinsax's Avatar
The Boot
I would assume that he would want to do this, in addition to it looking great, because it would be more cost effective....
Old Aug 26, 2008 | 09:44 PM
HondatagirlPea's Avatar
From: Between the hills of Downtown LA and Pasadena
Default Re: Adapting 1000RR cluster? (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote"> Have you thought about the stack gauges?</TD></TR></TABLE>
Have you thought about spending 2k on a dash?
And if so go with the Motec dash.
I have a Racpak in my car. Wires into your stock sensor such as speed,rpm,fuel level,turn signals,high beam indicator. Plus caomes with a few other goodies such as oil temp, oil pressure and water temp sensor. for 725 you can beat that.
Old Aug 26, 2008 | 11:39 PM
MidShipCivic's Avatar
You have to know the signal types it uses for the speedometer and rev/m and the rest is pretty much a walk in the park.
Old Aug 27, 2008 | 03:16 AM
sgnlab's Avatar
Default Re: (MidShipCivic)
I was planning on using one of these! $379.00
Old Aug 27, 2008 | 09:22 AM
Default Re: (sgnlab)
I would use a stack (love the tach), motec, or racepack cluster if I had that kinda of money to throw at it. Guess I'll just get a 1000rr cluster and give it a shot.
Justin
Old Aug 27, 2008 | 10:35 AM
Default Re: Adapting 1000RR cluster? (HondatagirlPea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondatagirlPea &raquo;</TD></TR><TR><TD CLASS="quote">
I have a Racpak in my car. Wires into your stock sensor such as speed,rpm,fuel level,turn signals,high beam indicator. Plus caomes with a few other goodies such as oil temp, oil pressure and water temp sensor. for 725 you can beat that. </TD></TR></TABLE>
Which racepak are you using? I thought you needed to use there V-net cable?
Justin
Old Aug 27, 2008 | 03:29 PM
Blown90hatcH's Avatar
Default Re: (Justin Olson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">I would use a stack (love the tach), motec, or racepack cluster if I had that kinda of money to throw at it. Guess I'll just get a 1000rr cluster and give it a shot.
Justin</TD></TR></TABLE>
Let me know what year you get and I will see if I can help out with the wiring.
Old Aug 27, 2008 | 04:35 PM
Default Re: (Blown90hatcH)
I'm looking at a 2005 cluster. If you could tell me the wiring pinout that would be a great help.
Regards,
Justin
Old Aug 27, 2008 | 05:58 PM
Justin Jones's Avatar
what a great idea, I am loving that 1000rr cluster. I'm gonna be on the lookout for one now.
Old Aug 28, 2008 | 06:28 AM
xci_ed6's Avatar
Default Re: (Justin Jones)
probably just need some signal convertors, I remember seeing them but I don't know where. The rr cluster probably expects 1 pulse per revolution for tach, I don't have a clue what the speedo would be. Temp sensors are probably the same, but you will need to check the fsm for specs.
I was thinking of using an F4i cluster.
Old Aug 28, 2008 | 07:17 AM
Mr.E.G.'s Avatar
subscribed
Old Aug 28, 2008 | 10:29 AM
Default Re: (Mr.E.G.)
With a racepak street dash no vnet is needed.
Vnet is only needed if you want to display other readings such boost,air temps and etc.
with the street dash you configure it to your car. for the speed you drive at 30mph for 1/4 of mile so that the dash can setup the speed signal type.
for 725 you cant really beat it.
Old Aug 28, 2008 | 11:06 AM
BLACKLIST138's Avatar
Default Re: (HondatagirlPea)
a stack instrument cluster is 1300 from pegasus with all the sensors.
Unless you need a lap timer, that ***** under 1500 shipped.
Id take ole boys suggestion and get the racepak. Those are really nice units. AIM makes a good one also.
I just dont see alot of need for a 13k rpm tach though. seems pointless since any cam made for a honda does not make power past 10 most times.
Old Aug 28, 2008 | 06:01 PM
Turbocivic94's Avatar
Default Re: (BLACKLIST138)
I'm pretty sure he doesnt want to spend that kind of money. He doesnt want to rev to 13K but its nice to have.
Old Aug 28, 2008 | 06:58 PM
Top Ramen's Avatar
Default Re: (Turbocivic94)
Do a build thread; I have considered using bike clusters on a couple of cars, but it just never worked out (timing wise). Would love to see how it turns out and would really love to have you sort out any signal conversion issues so I don't have to. ; )
Old Aug 28, 2008 | 07:34 PM
raiden571's Avatar
subscribed. i was considering using a cbr1000 cluster for my car down the line, would love to see you get this working. best of luck man
Old Aug 31, 2008 | 12:16 AM
turbob18si's Avatar
Default Re: (raiden571)
in for more info
Old Sep 3, 2008 | 05:29 PM
esteen2's Avatar
Default Re: (turbob18si)
You might want to check out http://www.hrtuning.com, look for the tunerview dash kit. Here is mine.
Old Sep 10, 2008 | 08:08 AM
nadadvan's Avatar
Default Re: (esteen2)
Whoa! This is really interesting. Those cluster are ill. I looking forward to the wiring required to hook it up.
Old Sep 10, 2008 | 11:23 AM
92TypeR's Avatar
FSAE
Default Re: (nadadvan)
We were thinking of using that exact dash for our Formula car.
I have the wire diagram for it. I'll post a link tonight when I get home.
Old Sep 10, 2008 | 01:50 PM
defnu's Avatar
Default Re: (92TypeR)
"We were thinking of using that exact dash for our Formula car.
I have the wire diagram for it. I'll post a link tonight when I get home. "
looking forward to this...my friends doing this to his track car and was wondering if i can help him with the wiring
jdm_vtec
Dec 2, 2007 12:35 PM
Dr.Colossus
Feb 23, 2007 04:23 PM
JDMTRSPORTS
12
Oct 28, 2005 01:47 PM
turkdog
Jun 24, 2003 04:01 AM
