EG6 cluster problem help!!!!!!
alright well i had one cluster already and it messed up so now that i got the new one the rpm gauge works perfect now the kmh doesnt move at all im thinking its my speed sensor any suggestions
Re: EG6 cluster problem help!!!!!! (DB1JDMRHDstreetsleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB1JDMRHDstreetsleeper »</TD></TR><TR><TD CLASS="quote">How do you take out the cluster on the EG's? Is it very hard?</TD></TR></TABLE>
Nope.
1. Remove two screws at the top of the dash bezel.
2. Pry the hazard switch with a flathead and remove screw behind the switch.
3. Remove the dash bezel.
4. Remove the four screws holding the cluster to the dash.
Nope.
Re: EG6 cluster problem help!!!!!! (JDMTRSPORTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTRSPORTS »</TD></TR><TR><TD CLASS="quote">alright well i had one cluster already and it messed up so now that i got the new one the rpm gauge works perfect now the kmh doesn't move at all im thinking its my speed sensor any suggestions </TD></TR></TABLE>
if your RPM's work and the KMH don't, then is the VSS. i had the same problem.
1st before you take out your dashboard. try unplugging the VSS and clean it with carb cleaner. you can get the carb cleaner at autozone. the wait for it to dry and plug it back in. then take the car for a drive and check if the KMH works.
if that doesn't work the go with this.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Nope.
4. Remove the four screws holding the cluster to the dash.</TD></TR></TABLE>
Nope.
Re: EG6 cluster problem help!!!!!! (Bartman201)
on my old cluster i bought it for 50 bucks so u get what u pay for my kmh did work at first and than it just stoped working and my check engine light went on, and also the rev needle on the old cluster didnt match up with my car.
so now with the new one, the my rev needle works perfect but my kmh wont work and i throw an engine code and whats a vss thanks for the help
Re: (EG1.8cT68)
ill have to learn how to find out what codes my car is throwing but if it were the vss where would that be located at? pics would be helpful
Re: (JDMTRSPORTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTRSPORTS »</TD></TR><TR><TD CLASS="quote">ill have to learn how to find out what codes my car is throwing but if it were the vss where would that be located at? pics would be helpful </TD></TR></TABLE>
the VSS is on the trany. it will be closed to the starter, ill take a pic and ill post it in the morning. what motor do you have on your car.
The VSS is actually pretty simple, if you need one I have one kicking around because I thought mine was crapped out. But it was just my cluster. The speedo might be just kicking in and out like mine was, I just bought a cheap cluster and swaped the speedo out. I say if you can borrow a cluster from someone for a day then test it, and if that cluster doesn't work then you know for sure that its the VSS.
I did replace my cluster with my stock one still nothing so im guessing its my VSS LMK if someone has one for a 92-95 civic with a d15B swap
