WTB Turbo Oil Line Fitting, Crx Rear disk Prop Valve
WTB Proper proportioning valve for a crx with the rear disk swap...i believe 40/40??
Also, I need the fitting that goes between my block fitting and the oil line...
Here is pics of what i CANT use that i already have...
I also need an oil restrictor unless this fitting i have is correct..It fits the turbo..
I need the Peice that is where the brass peice fits the oil line...BTW Its a 14b turbo
See...it doesnt fit the Block fitting...
I need these parts ASAP So plz lmk!!! PM is best!!!
Re: WTB Turbo Oil Line Fitting, Crx Rear disk Prop Valve
i have a ATP retrictor
http://www.atpturbo.com/Merchant2/me..._Code=ATP-OIL1
$12 shiped
OR i have a function 7 Flanged retrictor
$20 shiped
$12 shiped
$20 shiped
MGS1098 PMD
importdude, The turbo i have is a TD05H, 14B off an eclipse, i think the restrictor u have is for T series??? LMK If it will work ill prolly still need it...
