MD FS: 92 HONDA CIVIC DX HATCHBACK H2B DRAG CAR !!!!!!
Means of contact: pm or txt 443-365-5471
not parting out
can be tagged historic and driven on the street!
i have receipts for everything!
Description:
Car
92 civic dx salvage title was pushed in a little in rear I had it pulled and straitened professionally at a body shop and then put a different bumper on it but the bumper is red little rust in rear minor imperfections here and there 1000
92 makes it historic !
6 point cage 500
Gsr rear disk brakes 200
Carbon fiber hood faded some just needs to be buffed 200
Integra front cloth seats 150
Stainless braided front brake lines 80
Complete wire tuck 250
Brake line tuck 100
Nrg quick release steering wheel with short hub 200
Wilwood brake booster delete 140
Rear cnc staging brake 170
Fluidyne radiator with slim fan 250
Innovative solid mounts 350
Custom threw headlight intake can be ran inside headlight or outside 150
-Engine
Made 224whp on a dynojet on a 110 deg day and a huge tire more making like 240~hp
H22a closed deck stock block bottom end with manual tensioner conversion950
esp d series alternator belt with crx alternator 200
Two -10 breather lines off of valve cover to moroso catch can 200
Qsd h2b kit 800
Rlz radius valve job 300
Skunk 2 pro1 cams cams fully degreed in 550
Skunk2 dual valve springs 260
Skunk2 retainers 160
Arp head studs 100
Welded and shaved intake manifold only thing is iat also fully ported 100
Custom size exit header with burns stainless 4-1 megaphone with reversing cone 800
M factory magnetic drag plugs for motor and trans 30
Aem fuel rail
Acura rdx injectors with adapter top hats and clips one of the best injectors out there
Adjustable fuel pressure regulator
-Trans
99 b16 trans fully rebuilt less than 10 passes on trans with quaife lsd all new bearings and syncros 1100
Comp stage 5 four puck unsprung clutch 395
Comp lightweight flywheel 205
Stainless braided clutch line 80
Torco rtf transmission fluid 60
Deist transmission blanket 200
M factory solid shifter bushings 40
-Electronics
Hondata S300 mounted on vibration mounts 700
S300 tuned on 93 octane and e85 by tempest racing 500
Auto meter tachometer with shift light 60
Auto meter volt oil psi, water temp gauge 40
Painless wiring battery cut off 100
Ngk afx wideband 250
255hp fuel pump 80
-Suspension wheels
23 13” m&h slicks on v2 drag wheels 800
Rear vx Honda wheels 50
Skunk2 extended lug nuts and studs 120
Sunk2 lower control arms 200
Beaks tie bar 100
Tein basic suspension 600
Full race traction bad not installed 300
Lots more I could keep the list going but this is what I can think of for now
$14170 of parts and stuff I can think of more than that invested
Pictures:
video
not parting out
Description:
Car
6 point cage 500
Brake line tuck 100
-Engine
Qsd h2b kit 800
Arp head studs 100
Aem fuel rail
-Trans
-Electronics
255hp fuel pump 80
-Suspension wheels
Beaks tie bar 100
Pictures:
video
