Transmission & Drivetrain Gearboxes, Differentials, Clutches
S2000 Slave/Master replacement
Old Aug 29, 2008 | 05:18 PM
dagle's Avatar
Default S2000 Slave/Master replacement
so i finally got the master replaced, and the slave too. the slave/master replacements seem to be okay (move freely/evenly without notches) anyways, so i put the master/slave on and i get about an hour of regular pedal and it just seems to progressively get softer until theres no pedal again.. (i bled it until even flow of liquid was coming out) but thats not where the problem lies i dont think..
so i got under the car (without a floorjack or jackstands, but honda jack + cinderblocks and whatnot) and i see that the ball/piston of the slave cylinder isn't pushing against the pressure plate (which explains it perfectly) but the problem is, that thing the slave pushes against, is stuck and so i can't re-install the slave cylinder properly..
how do i free it so that i can freely position the slave cylinder? has anyone ever encountered something like this before? I'm also pretty sure its not the clutch itself because i got a good pedal feel the first time i bled it.
Old Aug 29, 2008 | 05:19 PM
dagle's Avatar
Default Re: S2000 Slave/Master replacement (dagle)
im gonna try to borrow a camera to take pictures of what im talking about
Old Aug 29, 2008 | 06:56 PM
dagle's Avatar
nm problem solved for now at least.. release fork is what its called haha
twiztid00002
Oct 7, 2008 11:23 AM
ianae86
Mar 16, 2006 01:59 AM
superfuji57
Sep 28, 2004 01:02 AM
97teg415
Aug 1, 2002 09:45 AM
