Transmission & Drivetrain Gearboxes, Differentials, Clutches
no third gear
Old Apr 19, 2009 | 04:02 PM
1990_integra_DA9's Avatar
Default no third gear
So a friend of mine got done with a b16 motor/tranny swap. And he cant go into third gear while the engine is running. But with the car off it goes into third just fine. Does anyone have any input on what the problem may be? its has a hydro to cable conv. on it.
Old Apr 19, 2009 | 07:44 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: no third gear
all the other gears shift fine? does it grind 3rd or he's blocked out? does it feel normal when the engine is off and he shifts into 3rd (no resistance)? and i take it he's driving regularly when he tries to shift? with or without the clutch, see if it goes in with a 1000 rpm drop from 2nd into 3rd.
Old Apr 20, 2009 | 03:57 PM
YEah everything else shifts normal. He is blocked completely out of thrid gear. When the engine is off it shifts normal. It wont go into third at all with the engine running.
oresama
Jul 29, 2018 08:46 PM
Metalluthier
27
Jul 11, 2006 10:34 AM
matt87
82
Sep 15, 2005 03:11 PM
