Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hard shifting
Old Oct 26, 2009 | 07:00 PM
gsrjdmb18c's Avatar
Default Hard shifting
I just put new pilot bearing, new aluminum 8lb fly, new clutch and pressure plate, and a new throw out. Now when at a stop its hard to shift into any gears so I bled the slave and still doing it. I noticed if the clutch pedal is to the floor and the trans is in gear i hear some kind of noise like the noise u hear when machining rotors. Then i noticed if i let the pedal out about 1/3 to 1/2 inch it shifts into gear normally and no noise. What could this be? Should I adjust the clutch pedal height? Or is it something else?
Old Oct 26, 2009 | 07:22 PM
Aquafina's Avatar
Default Re: Hard shifting
Clutch pedal needs to be adjusted after installing a clutch. Bleed it more. Sure you installed the clutch correctly?
Old Oct 26, 2009 | 07:25 PM
gsrjdmb18c's Avatar
yes it only went in one way will not go in the other way i checked. which way should i adjust it down or up?
oXeNo
Jul 30, 2011 09:12 AM
SuperTuner12010
Nov 27, 2009 06:56 PM
EKJOE
Jun 2, 2009 07:38 PM
EJ8VTEC
18
Jul 1, 2005 12:30 PM
wilntegra
May 3, 2005 04:22 PM
