Transmission & Drivetrain Gearboxes, Differentials, Clutches
gsr tranny vs b16 tranny question
Old Jan 4, 2011 | 05:12 PM
  #26
ej8_99's Avatar
Default Re: gsr tranny vs b16 tranny question
Originally Posted by MonkeyMagic
but if you don't have it.. $500 or $5million dollars.. doesn't matter, it's just to much.
i agree
Old Jan 4, 2011 | 05:23 PM
  #27
ej8_99's Avatar
im on a sort of low budget. if you guys can find me a ctr or itr tranny for around 700 than ill think about it. all i was asking in the first place was which one is better gsr or b16 because those are the two that i like. ya ctr and itr are cool but theyre expensive as hell and i just dont know if i could sleep at night knowing i spent that much on a transmission. i know i know theyre bad *** trannys but i just couldnt do it. i have found b16 that need a new third syncro for 200 dollars. thats an easy fix for still cheaper than an itr or ctr. but now that i know that gsr's seem better and more reliable then thats what i want. so.... anyone sellin a gsr tranny?? haha
Old Jan 4, 2011 | 05:43 PM
  #28
Libertariat's Avatar
Ek Forever y0!
If that's really all the b16 needs and you're comfortable with taking transmissions apart that is a steal for $200.
You could get teflon coated 3rd gear synchros and an OBX lsd and you'll have a badass setup for cheap.
Old Jan 4, 2011 | 05:44 PM
  #29
94EG8's Avatar
Seagull Management
Except that normally once they start grinding you need the sleeve and gear too, and they aren't cheap.
Old Jan 4, 2011 | 05:47 PM
  #30
Ek Forever y0!
yeah and if you're going that far might as well replace the whole thing.
Old Jan 4, 2011 | 05:56 PM
  #31
94EG8's Avatar
Seagull Management
IIRC it all comes as an assembly from honda, gear, hub, syncro, syncro spring and sleeve. Its a considerable amount of money, but of you can do the work yourself and the other gears are all good it would be worth it over buying another used B16 tranny for more money that may have a worn syncro that isn't grinding yet. Make sure that 2nd is good though. 1st/2nd syncro and sleeve set is over $400 from honda, 2nd gear itself is another $110 or so. Can be had cheaper from majestic honda.
Old Jan 4, 2011 | 06:14 PM
  #32
95b18c1egcoupe's Avatar
i gotta stock b18c1 in an eg coupe with a gsr tranny and it is a beast on the street. and it still does good on gas and isnt bad on the highway thats what i would go with
Old Jan 4, 2011 | 06:15 PM
  #33
Ek Forever y0!
For that kind of money you could order custom gears aftermarket a lot cheaper.
Old Jan 4, 2011 | 06:16 PM
  #34
Ek Forever y0!
You're thread jacking.
GSR should be pretty solid for gas mileage. Changing gears or transmissions won't do much for you. It's much more likely an ignition issue that's affecting your mileage.
Old Jan 4, 2011 | 06:27 PM
  #35
i wasnt stealin this thread i was jus tryin to help this guy out by sayin the gsr tranny does good on the street and is still good for the track. i mean the gearing is good enough that mine spins through 3rd gear easily. i have put down high 14's while spinning through 3rd 1t 93 mph and my car is a full weight ex coupe its weighs 2550 with me in it it runs real good with the gsr tranny so thats what i would recommend for this guy.
Old Jan 4, 2011 | 06:35 PM
  #36
dfJDM's Avatar
whats an eg coupe? i have a ej coupe, never seen an eg.
Old Jan 4, 2011 | 06:45 PM
  #37
ej8_99's Avatar
lmao!!!!
Old Jan 4, 2011 | 06:48 PM
  #38
ej8_99's Avatar
yeah i have made up my mind. gsr tranny for sure. probably lsd and carbon syncros and be done. thanks guys yall were a lot of help
Old Jan 4, 2011 | 07:06 PM
  #39
dfJDM's Avatar
honestly that sounds like a decent set up dude, do what you can afford, lsd will definitely make the difference. my buddy is running ls/vtec with a gsr lsd tranny and it makes me wanna kill him, ls trannys suck.
Old Jan 4, 2011 | 07:22 PM
  #40
ej8_99's Avatar
ya dude i had one and i hated it. i have a built gsr high compression and i was just wanting a good road/track tranny for it. who makes good cheap lsd's?
Old Dec 2, 2012 | 11:03 AM
  #41
fukb20's Avatar
I would keep the gsr and change the final drive to itr and I would do the ls 5th gear carbon syncro that's joust my thoughts
Old Dec 3, 2012 | 07:29 AM
  #42
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Way to bump the DEAD!!!
Rheg6
16
Jan 24, 2009 05:54 PM
b20vcrxsir
Aug 3, 2008 06:35 PM
SikofFalln
Jun 1, 2008 12:42 AM
EGLUVN
51
Aug 21, 2007 09:41 AM
SD1222
Jan 19, 2005 02:28 PM
