Transmission & Drivetrain Gearboxes, Differentials, Clutches
Drivetrain Slack?
Old May 28, 2020 | 12:05 PM
Kindled Light's Avatar
Default Drivetrain Slack?
Hello. I own a 1999 Honda Civic Si with the original B16A2 and S4C gearbox. I've owned the car for 3 years and am the 2nd owner. It currently has 107k miles and ever since I bought it at 83k miles its had a problem with bucking with on/off throttle and clutch engagement/disengagement.
I have replaced both the halfshafts with DriveShaftShop axles. I replaced the torque mounts with HardRace ones. Transmission and Engine drivers side with Honda OE Mounts. The rear mount was replaced with Honda OE, and then Innovative 75A Polyurethane mount as of recently to see if it would help with the problem at all and still bucks. It does this moreso in lower gears and is less prevalent in higher gears. The only things I havent done are cracked open the gearbox or replaced the center shaft in the driveline. What could be my issue here? Differential? Transmission? Voodoo?
Old May 28, 2020 | 12:23 PM
Aquafina's Avatar
Default Re: Drivetrain Slack?
So the car is bucking or just the transmission? What clutch are you running?
Old May 28, 2020 | 12:25 PM
The entire engine/drivetrain assembly. The clutch is a stock replacement at 90k miles along with the pressure plate and flywheel. It did the same both before and after the job.
Old May 28, 2020 | 01:35 PM
Ryanthegreat1's Avatar
Broken/worn spiders in the differential will cause excessive slack. So will a worn shaft the spiders ride on. They get burned up in a hurry with one tire fire burn outs.
Old May 28, 2020 | 01:40 PM
So this could warrent the need of a new differential? I never pealed out in my car or had harsh takeoffs. Ive driven it hard before but I always let the rpm settle and I don't speed shift.
Old May 28, 2020 | 01:52 PM
PO could have done plenty of burn outs.
Old May 28, 2020 | 01:55 PM
Possibly. I never would have thought of it considering it was well kept and doesnt really have many issues besides this. I mean small stuff and the A/C but it just seemed old overall. Oh well. LSD time might be coming sooner than I thought if thats the case lol.
rish7
Honda Civic (2006 - 2015)
Mar 29, 2017 02:05 AM
9thgenidiot
Nov 23, 2015 01:51 PM
Cabletie
Jun 26, 2014 01:36 PM
bama35633
Dec 26, 2009 06:09 PM
Turbo-Tec
21
Jun 17, 2005 06:31 PM
