Clutch or trans problem
I have a ls swapped ek hatch 5 speed. I started my car the morning and everything was fine. Let it warm up before i left home. Went outside and it was off. Figuredit just cut off. Went to start it and let out the clutch and it jerked and stalled out. Its like it is stuck in gear. And the car is a neutral. With the front wheels off the ground the wheels will spin while car is in neutral. It will go into gear but the engine just dies out when i try to move. There is fluid in the clutch master cylinder. The clutch pedal would drop to the floor after sitting a few hours. But since this problem it has been firm. I also have bleed the system but there was no air in it and still no results. slave cylinder does push out the fork probably more then a half an inch. Also the trans fluid was low but i did fill it up. Any other info that could be helpful just let me know.
