Transmission & Drivetrain Gearboxes, Differentials, Clutches
cable lsd in to hydro trans?
Old Dec 7, 2008 | 12:51 AM
Stillo's Avatar
Icon3 cable lsd in to hydro trans?
i recently bought a cable b16 lsd trans and it turned out the gears needed replacement.
a friend of mine has a freshly built b16 hydro trans, but with my setup i need lsd.
so my question is can i put the lsd from the cable trans in the the hydro trans with out any problems?
Old Dec 7, 2008 | 06:23 AM
Stillo's Avatar
Morning bump
Old Dec 7, 2008 | 10:25 AM
Aquafina's Avatar
If its not an OEM B16 LSD you can.
Old Dec 7, 2008 | 12:28 PM
Stillo's Avatar
Yes it is an oem lsd, out of a cable b16 trans
Old Dec 7, 2008 | 12:45 PM
Stillo's Avatar
According to the hybrid forum you can put a hydro diff into cable trans. So why can't you put the cable diff into a hydro trans?
Old Dec 7, 2008 | 12:50 PM
Aquafina's Avatar
You can, but since you have the OEM B16 LSD, you would have to swap the FD over as well.
Old Dec 7, 2008 | 01:36 PM
jdmdb8r's Avatar
Ive done it..oem gsr hydro with an oem cable lsd...you just have to shave down a part of the inside of the casing...
Old Dec 7, 2008 | 02:16 PM
Stillo's Avatar
Right that was also mentioned in the thread as well. Will that make a differnece in my gear ratios since the cable b16 trans has slightly shorter gears than the hydro b16?
As far as shaving the casing down, that shouldn't be a problem
Old Dec 7, 2008 | 04:56 PM
Aquafina's Avatar
Some cable B16's have longer gearing than hydro, none are shorter.
Old Dec 7, 2008 | 08:34 PM
Stillo's Avatar
so will the final drive of the cable trans in the hydro make a difference?
Old Dec 7, 2008 | 09:36 PM
Aquafina's Avatar
Depends on the ratio.
MastaFlyMason
Jul 4, 2018 04:47 PM
Wheelman-CZ
Nov 13, 2007 10:52 AM
rkrone
Sep 21, 2007 08:18 PM
b16a1eg6
Mar 16, 2007 09:40 PM
mugenzcrx
Jul 10, 2002 02:52 PM
