Transmission & Drivetrain Gearboxes, Differentials, Clutches
B-series transmission teardown/rebuild tutorial
Old 01-06-2009, 08:06 PM
  #51
Honda_San's Avatar
Default Re: B-series transmission teardown/rebuild tutorial
c clip was tight this was b/c i had the bolts too tight...
the shifter will now go into 3rd and 4th because i had to fix the mechanism that actually moves the shift rods....i had it in the wrong position and had to correct that...but idk bout 1st 2nd and 5th...are they just more difficult to get into?
Old 01-07-2009, 12:17 PM
  #52
Honda Bull's Avatar
Yeah. You definitely can't tighten the case down very far until you spread the c-clip. And even then, I leave the case a bit loose until I get the countershaft in. Then finish tightening those four bolts down. All of the gears should be about the same to get into gear. 5/R can be a bit tough at times though. But 1-4 should be butter shifting it by hand.
Old 01-07-2009, 02:12 PM
  #53
building boost's Avatar
just wondering if you ever installed this tranny, and did the grind go away?
Old 01-07-2009, 06:52 PM
  #54
Honda Bull's Avatar
I have not unfortunately. It probably won't be until spring that I get around to doing that.
The synchro ring will definitely help out quite a bit though. My only real concern is if some of the wear on the synchro hub has been causing the slight 3rd gear grind.
Old 01-13-2009, 02:36 PM
  #55
vinuneuro's Avatar
Outstanding work Bull! Thanks for taking the time to put this together.
Old 01-13-2009, 05:20 PM
  #56
eda6's Avatar
my y1 and s1 trannys were opened 8 times before i got it right. for those having issues with the countershaft c clip....a 1/2" drive extension works wonders for keeping that c clip open when putting the case halves back together.
also i think it's a good idea to replace the interlock while you're in there.
Old 01-14-2009, 02:44 PM
  #57
dr_latino999's Avatar
Quality write-up, I've saved it for future linkage.
Old 01-14-2009, 03:24 PM
  #58
BULLYAHOLIC's Avatar
whats the deal if my input shaft wont spin freely once everything is back together.
Old 01-19-2009, 09:01 PM
  #59
ej1 rep's Avatar
This thread is suuuuper helpful, I was wondering if you could give a little more clarification if you top bearing gets stuck in the case, I tried to tip it upside down and tap it out and tryed to pry it out but no succes.
Also is there somewhere that I can get those tiny ball bearings that come out of the holes on the side of the case? Honda maybe?
Old 01-23-2009, 08:57 PM
  #60
92integraVTECgsr's Avatar
nice write ups.
I just started messing with transmissions, but I put mine back together like Aquafina said. Just turn the case ove while holding it in the air and it snaps into place. Never dropped mine.. Just sounds scary.
But I definitely learned a little more about the syncro sleeves and which sides are which.
Old 01-24-2009, 07:57 AM
  #61
Honda Bull's Avatar
It's not correct. lol You may have two gears selected at one time, may have put the washers on the mainshaft on the wrong way, etc. A lot of things can happen.
I've had that work a couple times, but normally it won't go in like that for me. I've always had to tap it "LIGHTLY" against something. It's not scary. lol We're not dropping it from 10 feet in the air.
Honda or Acura dealers will have them. Not sure if they come with the spring and bolt, but you may be able to buy them seperately.
Old 01-27-2009, 06:35 AM
  #62
89civic1.8T's Avatar
I have a 94 GSR and it has always had a loud input shaft bearing. It shifts very good though. Yesterday on the way to work. I started out in 1st gear and got a loud clunk. Car didn't go anywhere. It felt as if I lost my tranny. Couldn't feel any gears with the shifter. Then It started working again. I was able to get it to my garage. It has a loud (Rod knock) type sound in the tranny. I am thinking (hoping) it's the input bearing I should have the tranny pulled out tomarrow night. Any idea's?
Old 01-27-2009, 12:49 PM
  #63
needahatch!'s Avatar
very nice write up! i think imma change mine when i rebuild the motor to put in the 4door.
Old 01-30-2009, 01:54 PM
  #64
transguy37's Avatar
Nice pics, I've done several of these units myself. Pretty sweet trans to do.
Old 01-31-2009, 01:49 PM
  #65
vti444's Avatar
superb write up, only questoin is should any thread locking compound be used on any bolts ?
Old 02-02-2009, 07:31 AM
  #66
ef92b's Avatar
no. just torque/tighten them to spec.
very nice illustration and pics. great write up!
i would like to share a pic of mine, a CTR/S4C LSD tranny internals into a YS1 cable tranny casing with LS 5th. all done at home, DIY'd the first time(thanks to one of the how-to's links Bense posted in the sticky and Helms manual as usual). it's been running smoothly ever since i swapped and made use of it.
Old 02-02-2009, 07:50 AM
  #67
akandok's Avatar
FAQ Material
Old 02-02-2009, 08:31 AM
  #68
PatrickGSR94's Avatar
wrd awesome write-up.
Coupled along with the Jeff Evans Tuning Youtube vids showing the actual transmission disassembly and differential replacement, I feel pretty confident I could tackle this myself.
Link to part 1 of 3 vids:
http://www.youtube.com/watch?v=PXG4YecAaaQ
Old 02-04-2009, 10:59 AM
  #69
Go Tigers!
Bense's Avatar
Excellent thread, Thank you for the time you invested in this thread. I'm adding it to the index/FAQ right now.
Old 02-04-2009, 11:05 AM
  #70
BlakeJ53's Avatar
supscribed
Old 02-04-2009, 04:01 PM
  #71
Go Tigers!
Bense's Avatar
Originally Posted by BlakeJ53
supscribed
is that a combination of saying "sup" and "subscribed" ?
Old 02-04-2009, 04:06 PM
  #72
Go Tigers!
Bense's Avatar
supscribed
Old 02-06-2009, 05:59 AM
  #73
Thank you very much for this thread. I was able to take my tranny apart and find the input shaft bearing was destoried. Inner race of the bearing was half gone. A few ***** were missing too. I got it back in last night and it's running great.
Old 02-06-2009, 03:51 PM
  #74
HT Chaplain's Avatar
this should be stickied
Old 02-06-2009, 06:49 PM
  #75
Go Tigers!
Bense's Avatar
If I were to make the most useful threads in this forum sticky, the whole first page would just look like a big list, and the topics wouldn't start until about page two.
That's why the index looks like a list
Quick Reply: B-series transmission teardown/rebuild tutorial
