B-series transmission teardown/rebuild tutorial
#328
Re: B-series transmission teardown/rebuild tutorial
Guys - quick one ..
S9B - while re-assembling, I have an extra ball from the bolt/spring/ball bearing.
There are two - on the shifter forks ..
Then there is a third on the shift rod assembly. Does anyone konw of any more? Could my mysterious forth have come from somewhere else?
Thanks!
Thanks!
#329
Go Tigers!
Guys - quick one ..
Thanks!
Thanks!
#331
question guys.
should there always be the 2 thrust washer at the base of the mainshaft the ones that sit on top of the bearing in the housing ?
i just split a 4.9fd y21 to check it over and it has no washers there ?
Thanks
Thanks
#333
Premium Member
I realize this thread goes back quite a ways, but it looks like the best resource if I need to go in and rebuild my B-series tranny (LX). It is a little resistant to getting into 2nd, and going back into 1st from a stop when cold.
#334
Go ahead and clean the transmission casings. Get as much of the old oil out as possible. You can do this with various substances. Carburetor cleaner works well. I try to avoid brake cleaner so that I don’t get any on the bearings. I had very little oil left in this transmission when I opened it up, so I didn’t even bother this time. Beyond that, you can pry out the magnet with a flathead screwdriver and wipe it off – if anyone has a great way to clean a magnet, please tell! Also, scrape off the old gasket sealer on the mating surfaces of both transmission case halves. Razor blades or gasket scrapers work well. Just be careful not to gouge the mating surface much with the blades. Then wipe it off with the carb cleaner and paper towel to keep it clean and dry.
Attachment 475510
Attachment 475511
Another thing to look out for which may hinder the sealing of the case halves are scores that may need filed down. Mine did have some damage, highlighted in orange, which I filed down and wiped down.
Attachment 475512
With that done, we can get back to reassembly. Put the differential back in. Next, align the gear clusters with the shift forks like so, and reinstall them in the bell housing.
NOTE: This is a billion times easier with two people, as it can be quite difficult to both hold the gear clusters and turn the differential if the countershaft’s final drive pinion gear is having trouble lining up with the final drive ring gear of the differential.
Attachment 475513
Attachment 475514
Once complete, install the shift change assembly and the reverse idler gear. Make sure that the shift rod in the casing is in neutral, as well as all three shift forks. In neutral, the shift assembly will drop down into its place in the casing. Just maintain upward pressure of the shift forks with right index finger and downward pressure on the shift change assembly’s alignment rod with your left thumb, as seen in the right photo. Once in, reinstall the three 10mm bolts. Only tighten them gently by hand, as they can be easy to strip out. In the left photo, you can see the pin on the reverse idler that needs lined up with the slot in the transmission casing.
Attachment 475515
Next, place the reverse change holder in its place, aligned with the 5/R shift fork and the reverse idler gear. Thread its two 10mm bolts in gently by hand. Finally, make sure to move the alignment tab of the mainshaft washer to roughly the 12 o’clock position – you can see where this tab locates in the upper casing.
Attachment 475516
NOTE: Before spreading the gasket sealer on the mating surface of the bell housing, it may be helpful to run through closing the transmission case once or twice if it is your first time. This may help eliminate any surprises and resulting frustrations. As much as I have done this, I still hit snags every so often. I had a differential bearing with a slight burr prevent the casing from falling down completely. I spent about thirty minutes looking for the problem before finding it, and by that time the gasket sealer was spent.
Comfortable with the next few steps, go ahead and spread the gasket sealer. I strongly recommend Honda Bond, as that stuff is probably used to seal cracks in the Hoover Dam, but I’ve used almost all variations of RTV Sealant (gray, blue, red, black) with great results. Yes, I was being cheap.
Attachment 475517
Once you have gasket sealer spread all around the mating surface of the bell housing, go ahead and slide the upper casing down over the gear cluster, making sure you don’t bump the tab you aligned at 12 o’clock. The picture on the right shows the “thumbnail” gap that you’ll normally see when the case bottoms out on the shift change assembly’s alignment rod.
Attachment 475518
The easiest way I’ve found to drop the case further down is to use a Phillips screwdriver and use it to select various gears in the transmission. I’ll normally go for 2nd to 1st, and then 4th to 3rd. At the same time you perform this, it may be beneficial to press down gently on the top of the case, although not required. The casing will drop down almost immediately as long as nothing is preventing it.
I’ve never been able to just spread the c-clip at this point and tap down on the casing to get the c-clip to seat, like some people claim. You can try this, though, to see if you find success with it. Instead, I thread four 12mm bolts (highlighted in pink) into the corners of the casing “finger tight”. Once this is done, I spread the c-clip (this time with a set of pliers I finally found instead of the two screwdrivers at the beginning of this tutorial). If the c-clip will not spread and stay open, thread the bolts down a bit further with a ratchet, but be careful that the c-clip is not being bent or damaged on the countershaft bearing.
Attachment 475519
Attachment 475520
Once the c-clip stays open, I pick the case up, flip it over, and drop it gently against a surface. EDIT per Blown90hatcH's request: To put the least stress on the transmission, and prevent any damage to the aluminum casing or internals, it is advised to drop the casing on to something that can absorb any impact - i.e. thick phone book, block of wood, etc. Also, sometimes it is possible to simply do this process in the air, without dropping the transmission. The weight of the countershaft will then cause the countershaft to slip down into the c-clip and lock it into the bearing’s guide for the c-clip. Like the noticeable “clunk” when you first opened the c-clip and dropped the countershaft, you will hear another noticeable “clunk” when the countershaft falls into place.
NOTE: If you didn’t clean out the oil in the casing, you may want to consider flipping the case over so that the bottom side of the transmission (the side which faces the ground when installed in the car) never faces downward. This will prevent any oil from seeping out through the gap between the two case halves where the gasket sealer is required to absolutely get a proper seal. Remember, gravity pulls down, so you want the best seal possible at the bottom and sides of the transmission, where the oil spends the majority of its life, sitting overnight and what not. This is easier if you just clean the oil out, though.
Flip the transmission back over and observe the c-clip. Make sure it is in properly.
Attachment 475521
Reinstall all of the 12mm bolts that hold the transmission halves together and torque them down to 20 lb.-ft. in a crisscross manner, starting from the middle and working your way out and around. Be sure to pay attention to any brackets that need to be installed with these bolts. These bolts will strip fairly easily if over-tightened. As a general rule, “hand tight” with a 3/8” ratchet will suffice and normally prevent any stripping. Reinstall all remaining pieces in whatever order you choose. It is a good idea to put sealer on the c-clip bolt’s threads. You can stay clean by using a ½” extension to install it and thread it in. It will torque down to 18 lb.-ft. Again, “hand tight” will work fine if no torque wrench is available. Over-tightening this can result in cracking the transmission casing itself. So be careful. The 14mm reverse idler shaft bolt is actually pretty tight. 33 lb.-ft. is recommended, “hand tight” on the tighter side works fine. Again, torque wrenches are always good insurance.
Attachment 475522
Attachment 475523
Attachment 475524
You can thread the two 12mm bolts in to the casing which contain the shift fork springs and ***** now, as well. I have found though, that putting them in with the transmission vertical can sometimes lead to problems with shift fork movement (I have jammed two shift forks this way in such a fashion that it would not move out of neutral when pushing the shifter). Instead, I have found it easier to install these with the transmission’s bottom facing upward. Prop it up with a board, and then drop the ***** into the holes. Thread in the two bolts with the springs and lightly tighten them (these strip INCREDIBLY easily). I think 12 lb.-ft. is required. Try whichever way you wish, but this way has worked flawlessly every time for me.
Attachment 475525
Attachment 475526
Go ahead and flip the transmission back over, test the motion of the mainshaft by spinning it several times both ways. Use that Phillips screwdriver to row through the gears, making sure the mainshaft still spins in each gear.
Congrats, you’re finished!
Attachment 475510
Attachment 475511
Attachment 475512
Attachment 475513
Attachment 475514
Attachment 475515
Attachment 475516
Attachment 475517
Attachment 475518
Attachment 475519
Attachment 475520
Attachment 475521
Attachment 475522
Attachment 475523
Attachment 475524
Attachment 475525
Attachment 475526
Ive a quick question 5th gear hub sleeve can that be flipped around
This has grove's on the in side.. My syncros are perfect and the hub's bad.. But only on one side.. Can i flip it around? Plz help this could fix it if so
#336
#339
Go Tigers!
#340
Well i went ahead today and did it and guess what.. Its now working and no grindes! So i had a grinde in 5th caused by the sleeve pictured above rotated it to the good side and wallah.. A buddy of mine is the genius that came up with the idea ...and it saved me 300 bucks
#341
i have everything installed how it is suppose to go and when i go to put the case on it goes down smoothly but doesn’t lay flat it has literally like a 16th of an inch of space and when i put the clip around the bearing i have to use bolts like you said but when i tighten then i can’t spin the main shaft anymore. it’s a gsr tranny
#342
Make sure the stopper ring is lined up properly, put case on, spread snap ring, push case on until its fully seated. If it won't push on fully, you have something assembled incorrectly and/or the mainshaft and/or diff are shimmed to a negative clearance. Do not use bolts to pull the case halves together.
#343
#344
i have everything installed how it is suppose to go and when i go to put the case on it goes down smoothly but doesn’t lay flat it has literally like a 16th of an inch of space and when i put the clip around the bearing i have to use bolts like you said but when i tighten then i can’t spin the main shaft anymore. it’s a gsr tranny. i took everything out and started with leaving the main shaft in by itself and still when i put the case on it doesn’t sit flat all the way and when i tighten two bolts i can’t spin the main shaft. the main shaft is assembled correctly as i followed many detailed videos to assemble it piece by piece.
#346
#347
The core of the mainshaft assembly to the transmission case. Core of the mainshaft being the mainshaft with collars, hubs and the top bearing. This is found in the Helms manual, which is vital if you want to properly assemble the transmission.
#348
#350
Hey man was just hoping to ask where you got the rebuilt kit from or if you know any good places to get a 3 gear synchro, 3rd gear, and 4th synchro for a y21 trans(from a b16a)
