Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch Replaced, Lower Pressure - Normal?
Old 03-09-2017, 07:51 AM
cander38's Avatar
Default Clutch Replaced, Lower Pressure - Normal?
Please forgive my lack of expertise here... I had the clutch replaced on a Honda Fit. It goes into gear fine and pressure is consistent, but it is considerably lower (the pressure) than before. Is this normal? I've never driven a car that had an old clutch and then a new one to know if this difference in pressure is normal or not.
Thanks for in advance to any replies!
Old 03-09-2017, 09:27 AM
Aquafina's Avatar
Default Re: Clutch Replaced, Lower Pressure - Normal?
Over time the pressure plate can fatigue but a new replacement should feel in the same ballpark. Is the replacement the same brand and model as the replaced?
Old 03-09-2017, 09:47 AM
cander38's Avatar
Thanks for your reply. I'd say it's roughly 30% less pressure. I do not know the brand or model they used. I took it to a local mechanic that was referred to us by several neighbors.
Old 03-09-2017, 03:30 PM
Aquafina's Avatar
If you can ind out that might shed some light on it. Does it disengage and engage as the same heights (pedal position) it did before?
dunked dc
04-09-2011 11:06 AM
spets
04-18-2008 11:55 AM
JDM_SOHC
36
05-21-2007 03:50 PM
1EK1EG
05-08-2007 05:42 PM
sohcvtec1995
11-20-2003 02:52 PM
Quick Reply: Clutch Replaced, Lower Pressure - Normal?
