ZEX Spark Plugs - worth it?
Old May 16, 2003 | 07:24 PM
Goldfingiz's Avatar
Default ZEX Spark Plugs - worth it?
Hey guys, I'm new to the nitrous scene, and my friend is getting his Zex kit in the mail this week. He has brand new Bosch Platinum +4's. Is it worth it for him to get the ZEX spark plugs? They're only $20, but is he just going to be wasting his time/money? He's only going to be spraying a 55 shot, maybe a 65 or 75 down the line, but not very often at all. He's set on 55.
Thanks,
Goldfingiz
Old May 16, 2003 | 08:56 PM
9200RPM's Avatar
Default Re: ZEX Spark Plugs - worth it? (Goldfingiz)
I wouldn't run the Bosch Platinums, they are too hot of a plug. Next the Zex plugs are great. They lasted about 8 months on my shops project cars. The only draw back to them is that they have 3 prongs, with N2o I have read it's better to have a single prog spark plug. (Please correct me if I'm wrong). NGK has a colder series of plugs available. See if you can get ahold of a set of them, and good luck!
cameron
Old May 16, 2003 | 10:33 PM
Goldfingiz's Avatar
Default Re: ZEX Spark Plugs - worth it? (TurboB16aEG)
Thank you
How would his car run with that cold of a plug off the juice? Any drawbacks?
Thanks
Old May 16, 2003 | 10:45 PM
sslude's Avatar
i would recommend getting the plugs. ive heard only good things about them
Old May 16, 2003 | 11:10 PM
9200RPM's Avatar
Default Re: ZEX Spark Plugs - worth it? (sslude)
Forgot to mention, another guys car I work with, 97 jetta, had a zex kit on it just a 55 shot. He left the Bosch plugs in it and ended up dropping cylinder 2. So he rebuilt and did a turbo motor...
Old May 16, 2003 | 11:21 PM
Goldfingiz's Avatar
Jesus Christ, how did that happen? Isn't this supposed to be one of the safest kits? It kills itself if the air/fuel ratio isn't right
Old May 16, 2003 | 11:31 PM
9200RPM's Avatar
He even had the timming retarted 2 degrees. Bigger injectors, stock fuel pump. I can't fully blame the kit or the plugs we didn't really inspect it before he tore it down....but it makes sence if he was running a hotter plug... As to what you said about running all motor on the ZEX plugs in the civic it was a D16z6 with 160,000 miles on it factory sealed with a ZEX stage 1 cam it and ran consistent 9.5 in the 8th.....
Old May 17, 2003 | 05:45 AM
DK4200's Avatar
Get NGK's i think the item # is bkr7e (don't quote me on that) i have them and they are great. I hear they are better then the ZEX plugs to.
Old May 17, 2003 | 09:02 AM
Goldfingiz's Avatar
Default Re: ZEX Spark Plugs - worth it? (DK4200)
Thanks for the help guys
He went ahead and ordered the ZEX plugs. He figured they can't be bad, and wont hurt since they were made for the kit.
Old May 17, 2003 | 10:52 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">Forgot to mention, another guys car I work with, 97 jetta, had a zex kit on it just a 55 shot. He left the Bosch plugs in it and ended up dropping cylinder 2. So he rebuilt and did a turbo motor...</TD></TR></TABLE>
Reason being, you can't run platinum plugs with nitrous.
I can't say all ZEX plugs are bad, I may have had a bad set, but they made my car misfire.
Old May 17, 2003 | 12:01 PM
ERA's Avatar
ERA
Default Re: ZEX Spark Plugs - worth it? (RyanCivic2000)
I disagree with the ZEX plugs being bad, could've been a bad set. I ran multiple plugs on my nitrous D16Z6 and had the best performance out of the ZEX only second to the stage colder NGK plugs. Car will run fine off the bttl too. The thing I particularly liked about the ZEX plugs was even when I was running 75 shot ADV 1deg on timing, they still weren't burning up like I thought they would. Leaner tha Meaner and they held up very well. Plus they're cheap as **** too.
Old Jul 20, 2003 | 05:59 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DK4200 &raquo;</TD></TR><TR><TD CLASS="quote">Get NGK's i think the item # is bkr7e (don't quote me on that) i have them and they are great. I hear they are better then the ZEX plugs to.</TD></TR></TABLE>
would bkr6e's work fine?
Old Jul 21, 2003 | 11:20 AM
vbphreak's Avatar
I second this! This is what I used when I ran my 55 shot.
umair
Mar 1, 2009 03:17 PM
smslude
Mar 6, 2003 02:12 PM
hondafrk
Oct 29, 2002 05:53 AM
WNT KCH
Sep 19, 2001 09:25 AM
