ZEX Comp Cams Spring & Retainer
Old Oct 10, 2005 | 03:30 PM
doublejz's Avatar
Default ZEX Comp Cams Spring & Retainer
will this kit work with a stock cam without chewing it up?
#89000-Kit (Steel Kit)
0.896" Outside Diameter / 0.600" inside diameter
Installed 50lbs. @ 1.950" / Open 170 lbs @ 1.450"
Spring rate 240 lbs./in.
Coil bind height 1.360"
Single spring coil for both intake and exhaust
753-16 Steel retainer
in a jdm b16a with skunk2 stock size valves.
Old Oct 10, 2005 | 04:27 PM
doublejz's Avatar
Default Re: ZEX Comp Cams Spring & Retainer (doublejz)
nobody?!?
Old Oct 10, 2005 | 07:54 PM
Lord Helmet's Avatar
You bother asking Comp Cams the maker of Zex about compatibility of the springs/retainer on the stock camshaft yet?
andrewjwatson
Apr 21, 2018 06:42 PM
Cho0se
22
May 16, 2013 07:24 AM
Golding.racing
Dec 12, 2011 11:24 AM
AlienKrOZ
May 12, 2008 10:20 PM
IntegraFanatic
Apr 1, 2003 10:13 PM
