ZC pistons =89 Integra ...
Old Oct 27, 2002 | 03:45 PM
No-Gi's Avatar
Default ZC pistons =89 Integra ...
Are ZC pistons the same as the 88-89 integra pistons?
Old Oct 27, 2002 | 08:21 PM
cracing's Avatar
Default Re: ZC pistons =89 Integra ... (B16aEK)
no they r not
Old Oct 27, 2002 | 08:50 PM
Sonny's Avatar
Yes, they are. I measured them myself.
The Integra piston looks a little different because the valve reliefs were sanded on this particular piston. Part number aside, they are the same casting.
Sonny
Old Oct 28, 2002 | 02:54 AM
D16Z6racing's Avatar
Default Re: ZC pistons =89 Integra ... (cracing)
no they r not
Is that why when you swap to a ZC, DOHC non-vtec, that they recommend 88-89 TEG parts.....I do belive so.
Old Oct 28, 2002 | 03:24 AM
No-Gi's Avatar
Default Re: ZC pistons =89 Integra ... (Sonny)
Thanks Sonny... I will now have a very high comp d16z6
Old Oct 28, 2002 | 06:02 AM
JaeOne3345's Avatar
yes..and u shouldnt have clearanced issues, but to be safe, CLAY the motor, because z6 valve location and a1 valve relief locations do not match up, even though i know about about 3 people running this set up with very high lift cams and very high revs without a problem
Old Oct 28, 2002 | 09:08 AM
cracing's Avatar
ya you can use them but i thought they had a diff dome size?
[Modified by cracing, 10:35 AM 10/28/2002]
Old Oct 28, 2002 | 09:42 AM
Sonny's Avatar
No, they are the same. I cc'd them.
Sonny
Old Oct 28, 2002 | 10:19 AM
builthatch's Avatar
MiG-21 superfan
verified they are identical. for the naysayers, you mite be referring to pg6 pistons which fit but are different than pm7 or p29...
Old Oct 28, 2002 | 02:47 PM
cracing's Avatar
Default Re: ZC pistons =89 Integra ... (buster13)
ya but its not all integ part you can use a 88 prelude timing belt and a crx water pump 88-89 integ intake manifold there are some many diff combos you can us.its not all 88-89 integ parts.i was off cuz i was thinking pm6 my bad.
[Modified by cracing, 3:48 PM 10/28/2002]
tommy.
Jun 20, 2009 04:28 AM
91civicDXdude
10
Oct 27, 2003 03:33 PM
SMSP
Sep 15, 2003 03:21 PM
WhatThaFrig
Jun 23, 2003 07:50 AM
crxnug
Nov 29, 2001 12:42 PM
