ZC and D16A1 questions
Old Mar 28, 2005 | 12:36 PM
SC-MK1's Avatar
Default ZC and D16A1 questions
Im going back to school soon, and cant afford to put a B series engine into my EF. So the only other choice I have is either a ZC engine or a D16A1 from a first gen integra. And I have a few questions about this swap in my 90' Civic Si.
Question 1: What parts will I need to make this a complete swap, like axles, ecu, shift linkage, mount or do I need any of these parts at all?
Question 2: Will parts like IM and Header from USDM D series engines fit on a ZC? Like a turbo kit for a 88-91 Civic, will the turbo manifold fit on the ZC?
Question 3: Will internal parts like pistons, rods, crank, bearings, and the likes from USDM D series engines fit in the JDM ZC?
And any other help on this swap would be great. Like what parts can be swaped over, anything at all would be great. Im new the the EF would and what works with them. TIA.
Old Mar 28, 2005 | 05:22 PM
SC-MK1's Avatar
anyone?
Old Mar 28, 2005 | 07:39 PM
SC-MK1's Avatar
cmon honda tech.
Old Mar 29, 2005 | 06:41 AM
SC-MK1's Avatar
ttt
Old Mar 29, 2005 | 06:47 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: ZC and D16A1 questions (SC-MK1)
You CANNOT put a D16A1 from an 86-89 Integra into an 88+ Civic/CRX without lots of fab work. All of the engine and tranny mounts are different. Make sure you get a ZC that fits 88+ cars. It is easiest to use your 90 Si tranny with your 90 Si flywheel, pressure plate and clutch. You should probably also use the ecu meant for the engine that you are swapping in.
Old Mar 29, 2005 | 07:39 AM
SC-MK1's Avatar
OK, so ZC is the best bet then. Anyone wana take a stab at my questions?
Old Mar 29, 2005 | 09:58 AM
staticchmbr's Avatar
Default Re: (SC-MK1)
most of the other parts will fit also. they have the same cylinder bore as other d series blocks. pistons rods, etc will work...ynot too sure about the crank though. you could also use a turbo kit from an 88-91 crx, but the exhaust manifold ports may not line up properly...very easy fix though. use a dremel to port out the manifold.
it should really bolt right in, but you need the zc axles and intermediate shaft if you use the zc tranny.
Old Mar 29, 2005 | 08:50 PM
FLOWZILLA's Avatar
Default Re: (staticchmbr)
zc for the us integra is classified as a side mount from most importers and the zc for your cars is a civic style zc parts are interchangable but not all are exact so they will not work to there full potential. there are many tricks to making a zc work very well if you are interested you can call us and we can help you with this we have done countless zc build up and have the experience to point you in the right direction our number is on our signature.. good luck with your project..
d0wnShiFt
Dec 19, 2010 03:53 PM
ludecrasy87
Nov 28, 2006 06:50 PM
sabretooth_22901
12
Sep 10, 2004 06:50 AM
EFin' Kyle
Jul 20, 2004 06:09 AM
scdarksol
12
Jan 31, 2004 06:38 AM
