Yes or No question
Old Jan 5, 2003 | 03:56 AM
thedon833's Avatar
Default Yes or No question
Can having incorrect camber make it appear you drive shaft is too long?
The reason I ask is I have a bad vibration on EG coupe b16a2 swap which is due to the axle being to long, the thing is the axle I have should work, I am using 99 si axle with 99 si half shaft. I can tell it is too long as there are dents at the bottom of the inner CV where the rollers are hitting the bottom, and this is causing the rollers to smash.
Thanks, Gavin.
Dylan Wall
Transmission & Drivetrain
Feb 16, 2014 03:17 PM
BigSorn
19
Oct 23, 2009 05:19 PM
cinci00si
May 18, 2009 06:39 AM
thedon833
Jan 5, 2003 04:51 AM
