Y80/LSD/rebuilt....
Old Aug 12, 2003 | 07:40 AM
Skyllz's Avatar
Default Y80/LSD/rebuilt....
I got me for a good deal a Y80 that I can see threw the diff without interference... So it should have a LSD. However I know the tranny is suppose to have problems shifting in 3rd and 4rth it was on a turbo GSR.
I am trying to make a damage assesment before sending it to my tranny guy to get a better estimate of the costs.
I was thinking 3-4rth gear synchro, probably the forks. Are gears something I should look into getting changed also or is it something I'll know when opening it up?
Anyway to check the LSD while it's out also for wear?
thanks!
Old Aug 12, 2003 | 01:56 PM
Skyllz's Avatar
ttt
Old Aug 12, 2003 | 02:15 PM
Mohudsolo's Avatar
Default Re: (Skyllz)
If both 3rd and 4th, I would suspect the fork. Probably damaged one of the gears and forced it in, bending the fork. I'm not sure you can get parts from anyone other than Honda. What is the trans for? There are aftermarket close ratio gears, if you are replacing them anyway.
Old Aug 12, 2003 | 02:31 PM
Skyllz's Avatar
I will most likely rebuilt with OEM parts
The tranny/car will be used for all out daily driving/a little of drag/auto-X/ect...
Old Aug 12, 2003 | 03:12 PM
Mohudsolo's Avatar
I figure taking it apart is free. See what the parts to fix it are and compare to buying a better one. Plus you can see what LS it has, factory, quaife, clutch type. So long as you have the skill to take it apart and tell what parts are bad, it's only your time. Plus any other used one could also have hidden problems.
DeFinitive
Transmission & Drivetrain
18
Aug 12, 2016 08:07 AM
si90rex
Welding / Fabrication
Sep 22, 2006 09:37 AM
speedKILLS
Jul 24, 2006 05:52 PM
Nextelbuddy
May 19, 2004 07:26 AM
cursED
Dec 31, 2002 07:59 PM
