WTF! cant pull an engine code... read on
Old Jul 7, 2004 | 07:32 PM
Ryan C's Avatar
Default WTF! cant pull an engine code... read on
I have a CEL and i cant pull the code. Yes, i know how to jump it. I am running a P28 socketed by RJardy with a chip that Tom (Tbone) made for me. [P30 scaled to 1.8l w/ 310's] My car runs but wont rev over 3500... what could be the deal?
Old Jul 7, 2004 | 07:34 PM
mmuller's Avatar
Mad Scientist
Default Re: WTF! cant pull an engine code... read on (Ryan C)
what happens when you jump it? nothing?
have you tried jumping it directly form the ecu
Old Jul 7, 2004 | 08:31 PM
Ryan C's Avatar
Default Re: WTF! cant pull an engine code... read on (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">what happens when you jump it? nothing?
have you tried jumping it directly form the ecu</TD></TR></TABLE>
when i jump it the light just stays lit.
how do you jump it directly at the ECU?
Old Jul 7, 2004 | 09:22 PM
mmuller's Avatar
Mad Scientist
ground the wire on pin D4
Old Jul 8, 2004 | 03:31 PM
Ryan C's Avatar
thank you sir, i'll post back up in a little bit
Old Jul 8, 2004 | 11:18 PM
Ryan C's Avatar
hmm. i grounded D4 and had no luck, i also tried my buddies P28 which was socketed by hondata themselves. i dont know what the deal is, there is no chance that its the chip, is there?
Old Jul 9, 2004 | 06:45 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">hmm. i grounded D4 and had no luck, i also tried my buddies P28 which was socketed by hondata themselves. i dont know what the deal is, there is no chance that its the chip, is there?</TD></TR></TABLE>
so you used the same chip with a different ecu and still the same problem?
yeah, it could be the chip, i mean...
Old Jul 9, 2004 | 07:03 AM
Ryan C's Avatar
gonna try a stock gsr ecu, i'll let you know tonight
Old Jul 9, 2004 | 07:44 AM
Used2beAb16's Avatar
sounds like the chip is having check sum problems.
Whenever u first turn the key on, does the check engine light come on and go out? Or does it stay on? if it stays on then it may be the chip and thats why it wont rev over 3,500 as well.
If the gsr ecu works than its the check sums of the chip he made. Try another chip.
Old Jul 9, 2004 | 07:47 AM
Default Re: WTF! cant pull an engine code... read on (Used2beAb16)
Oh i think i misunderstood, u tried your chip in another p28? Yes its def the chip then, its the checksums. If they dont agree than u will have a no go. Like i said in the previous post if the check engine light never flashes off when u turn the key to the "on" position thats the problem.
Old Jul 10, 2004 | 08:22 PM
Tad's Avatar
Tad
yo are you throwing a code with the ignition on and NO jumper in place?
if not, then i'm pretty sure it is normal that you cant bring up the code when you jump it.
Basically, I think whatever problem it is that you are having, is not a problem that would throw a CEL(however rare that might be).
but thats just my guess.
but yeah, swap out the ecu and see whats up.
u dont know anyone with a gsr?
Old Jul 11, 2004 | 06:27 PM
Ryan C's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">
u dont know anyone with a gsr?</TD></TR></TABLE>
i know an assload of people with gsr's, why?
Old Jul 11, 2004 | 08:24 PM
Tad's Avatar
Tad
Default Re: (Ryan C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">i know an assload of people with gsr's, why?</TD></TR></TABLE>
you said you needed a gsr ecu,
why not just borrow one for a min see if that fixes ur rev problem,
if it doesnt hten u know its something else!
UNKNOWN_MEMBER
Jun 9, 2005 08:09 AM
pisetup
Jul 12, 2004 02:53 PM
98HB
May 10, 2004 07:26 PM
TTWS6.
Aug 26, 2003 09:32 AM
4drGSR
Feb 23, 2002 10:53 PM
