Wrong Transmission?
Old Jan 31, 2006 | 11:42 AM
burningwrek's Avatar
Default Wrong Transmission?
I've been working on getting my b20b all together to drop in my 98 civic ex coupe. I attempted to bolt the transmission on today and it looked a little weird. This is my first attempt at installling a transmission, let alone an engine so I'm not positive as to what is wrong. The flywheel is exposed and it appears that all the holes for the screws do not line up. The three top screws line up fine and the dowels lines up but thats about it. Do I have the wrong transmission, which is supposedly a 98 LS hydro tranny, or am I missing something? Thanks guys.
Heres a pic of the side if this number means anything.
Old Jan 31, 2006 | 12:21 PM
bump before work
Old Jan 31, 2006 | 04:54 PM
PyroProblem's Avatar
Default Re: (burningwrek)
The flywheel is exposed because you dont have the cover for it. From the looks of it, it does appear to be the correct trans. Do you see a stamping on the top side anywhere that reads Y1 or S1 or something like that?
Old Jan 31, 2006 | 07:08 PM
Default Re: (PyroProblem)
ok, theres is a little black stamp on the top that reads "A5D" but I that was all my little brother could see. The motor is at my parents house so he ran outside and checked for me. I'll have to look next time I go over there to see if I can locate any other numbers on it.
Look at the bottom of the transmission in the pictures I posted? Are you sure thats right? that extension from the block doesn't even line up with the holes on the transmission. I didn't have much time to examine it though, I was kinda in a rush to go to work. Thanks for the help though, man.
Old Jan 31, 2006 | 07:33 PM
saywhat's Avatar
There is an inspection cover that goes over that part of the flywheel, if you go to the Acura dealership you can pick one up for $20, and look at some Integras there to get an idea of what it should look like.
Old Jan 31, 2006 | 07:35 PM
Default Re: (saywhat)
Ok, I'll snag that cover that I need. Thanks for the help, but as far as what you guys can see in the pictures, does it appear that I have the correct transmission?
Old Jan 31, 2006 | 08:00 PM
pennies_hatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I'll snag that cover that I need. Thanks for the help, but as far as what you guys can see in the pictures, does it appear that I have the correct transmission?</TD></TR></TABLE>
yep
Old Jan 31, 2006 | 08:12 PM
Default Re: (pennies_hatchie)
thanks a bunch guys. I'll check it out tomorrow after work and get that puppy bolted up.
Old Feb 1, 2006 | 10:40 AM
Default Re: Wrong Transmission? (burningwrek)
well i was able to check the tranny for myself and it says s80 on it, if that helps.
Old Feb 1, 2006 | 09:33 PM
badump
Old Feb 2, 2006 | 11:48 AM
vtecn8ive's Avatar
s80 i thought that was a GSR tranny
looks right. probably cause your old tranny was automatic that the one bar/bolt hole isn't lining up.
Old Feb 2, 2006 | 06:56 PM
Default Re: (vtecn8ive)
yea I thought the s80 was the gsr tranny too, but I found somewhere that the s80 was also the non LSD equipped LS transmission. Thanks for the help honda-tech homies.
Old Feb 2, 2006 | 07:04 PM
Those two bolt holes in the back your talking about are for the rear mount...Your good to go
Old Feb 2, 2006 | 07:10 PM
awesome man, I appreciate that definitive answer. And yea, the engine was previously mated to an automatic transmission.
Modified by burningwrek at 11:22 PM 2/2/2006
98ekls
Mar 18, 2014 07:55 PM
dyno76
Northwest (Sales)
Oct 7, 2010 06:15 AM
iwanttogofast
Nov 26, 2008 07:52 PM
dagle
Aug 18, 2007 12:18 AM
Seedc2
Oct 20, 2004 11:40 PM
