Would it be "smart" to cut this part?
Old Dec 26, 2003 | 05:58 PM
slvrcivic97's Avatar
Default Would it be "smart" to cut this part?
Well as some of you saw in my other post ( https://honda-tech.com/zerothread?id=713000) about my accident, I'm replacing my radiator support. However, before it gets here, I would like to cut this part of the radiator support shown below to allow me to remove the radiator and everything else behind it. Would it be ok to hack saw this part of the radiator support off where the green lines are?Since I'm replacing it, I don't see why not, but though I would double check. Thanks.
Old Dec 26, 2003 | 06:13 PM
myhatchrips's Avatar
Default Re: Would it be "smart" to cut this part? (slvrcivic97)
thats your radiator support. yes you can cut that but then you're also going to have to replace it. there may be some welding involved also.
Old Dec 26, 2003 | 06:29 PM
99blackcivicSi's Avatar
Default Re: Would it be "smart" to cut this part? (myhatchrips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips &raquo;</TD></TR><TR><TD CLASS="quote">thats your radiator support. yes you can cut that but then you're also going to have to replace it. there may be some welding involved also. </TD></TR></TABLE>
Jesus did you see the thing he has to replace it anyways. It is safe to cut it and take everything you need to off. just make sure everything is going to line up before you install the new on e
Old Dec 26, 2003 | 06:51 PM
CovertFI's Avatar
Default Re: Would it be "smart" to cut this part? (99blackcivicSi)
most of thoes parts are bolted in. check to see if that is bolted to the car before you cut.
Old Dec 26, 2003 | 06:59 PM
Default Re: Would it be "smart" to cut this part? (CovertFI)
awesome. Thanks for the help guys.
eecc
Acura TL, RL & ZDX
May 14, 2005 03:29 AM
tkHBseries
Feb 19, 2005 06:48 PM
JDM EJ1 95
Dec 28, 2004 10:39 AM
SuicideSlide
16
Sep 27, 2004 06:28 AM
