wobbly shifter
Old Jul 1, 2008 | 04:21 PM
B18EG6's Avatar
Default wobbly shifter
hey
I just installed a b series into an EF using Hasport mounts. I have noticed that the shifter is unusually wobbley, even when in gear. Is this due to a bad connection at the bitch pin? We used a new bushing at the stabilizer bar to tranny connection, for the two bolts that hold the linkage to the chassis.
Thanks
Seb
Old Jul 1, 2008 | 06:35 PM
downest's Avatar
Default Re: wobbly shifter (B18EG6)
Did you use a HASport linkage or a modified teggy one? Almost every HASport linkage I've seen has a lot of play, mine does for sure. A friend of mine sent his back and had it upgraded, it was better but not the best. The only real solution I've seen for this is to replace the U joint with a zero-play sealed joint.
Old Jul 2, 2008 | 03:49 AM
B18EG6's Avatar
Default Re: wobbly shifter (downest)
we used a Hasport linkage. I'll crawl under there and see if I can look where the play is coming from
Old Jul 2, 2008 | 05:50 AM
downest's Avatar
If you grab on both sides of the U joint and wiggle you'll be able to feel the play in it. Check this out. It's very popular with the number of CRX/EF customers we have running sloppy old linkages.
Old Jul 2, 2008 | 03:16 PM
B18EG6's Avatar
thanks for the link. We were unable to get the bitch pin all the way seated.. we were tired and sore as hell. Could this be some of our problem?
Old Jul 2, 2008 | 07:10 PM
downest's Avatar
It could be, but you should be able to feel where the play is if you grab it and move the linkage.
unautomobiled
26
Jul 16, 2014 05:07 AM
savageasfuc
Dec 9, 2011 08:46 PM
swizz977
19
Jun 12, 2011 08:31 PM
bigblueandyellow
Dec 27, 2004 12:34 PM
chhuong
Apr 9, 2002 12:00 PM
