wiring problems
Old Jul 8, 2001 | 06:38 PM
bigTom's Avatar
Default wiring problems
ok... iv rippeed apart and cut up most of my harness now (95 gsr harness) ... but i am confused what some wires are for... the first pic is the first issue... i cut off most of the wires leading to this... all which happen to lead to the abs... but ther a re a few wires that came from the rest of the wires... a white one, 2 yel/grn and one black... black is obviously a ground...
from my findings... all of the orange plugs are for abs... here are some... im guessing all the orange plugsa are for strictly abs... in that case i can get rid of those things in the first picture... am i correct
ok... next dilema... here i have 4 plugs from the passenger side in the front... off the main harness... (not the engine harness) the right one is the headlight... and the middle i am pretty sure is for the radiator fan... the two left plugs is what i cant figure out... i was looking at a friends gsr and it looks as if most go to something having to do with the a/c on the other side... they travel along the rad support... (the bigger plug) the plug (in case anyone wants to look at there car and figure it out) is right by the top of the radiator fan... the left side of it... and then the other plug just has two wires to it and it basically right by the bigger plug
here is one more pic of the two plugs i cant figure out
Old Jul 9, 2001 | 02:37 AM
PROFILES2000's Avatar
Default Re: wiring problems (4dr-gsr)
wow you really hould consider hand modeling
Old Jul 9, 2001 | 08:04 AM
bigTom's Avatar
Default Re: wiring problems (Y2kGsR)
Old Jul 11, 2001 | 02:34 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
the big plug is for the a/c harness that runs behind the bumper support. the two wire plug is for the radiator fan (make sure, usually a black ground and a blue/black). that should be it, hope that helps...i see an intercooler! nice, nice...is that the ek chasis? and you're putting a gsr powerplant? goodness.
vtecjunkiie631
Sep 15, 2018 07:19 AM
Steeve_Civic
May 7, 2012 12:42 PM
adictionbass
Jan 12, 2005 04:14 PM
bigTom
Jul 9, 2001 10:51 AM
