wire tuck gone wrong.
So I did a wire extension and tuck but one of the plus I cut off did not make is way back onto the car I cannot find where the other end of the wires are I think it might have something to do with headlights considering mine don't work. But the car is a 92 civic vx Canadian model. There are 5 wires. Black/yellow, white, blue/red,yellow, black/red
If the car did not come with A/C, then this plug would not be plugged into anything. The A/C compressor, dryer pressure switch and condenser fan relay/switch sub harness would plug into the 8-pin plug that you pictured. It would simply be mounted on the frame rail just behind the passenger side headlight. Usually, it is capped by a white end plug that has a "C" shaped clip on the bottom to locate the 8-pin plug over the wire loom of the headlight/parking light/horn harness. Many times, these are missing and the 8-pin plug is simply open.
thrasher324
Dec 28, 2016 01:59 PM
$amGD3
Audio / Security / Video
14
Jun 8, 2011 08:55 AM
