which wire to distributor for shift light? (b18c)
Old Nov 18, 2001 | 03:27 PM
ten_30's Avatar
Default which wire to distributor for shift light? (b18c)
anyone know which wire to tap on the distributor for a GSR? this is the signal wire for the shift light just in case u folks didn't know what i was talking about.
TIA
Old Nov 18, 2001 | 04:28 PM
Suprdave's Avatar
Default Re: which wire to distributor for shift light? (ten_30)
Blue Wire by distributor...My Advice is Tap it off the Gauge CLuster.
Otherwise you gotta run a wire in the engine bay. Like I did, and its ghetto. I'm re-doing it in the spring.
Suprdave
Old Nov 18, 2001 | 04:39 PM
ten_30's Avatar
Default Re: which wire to distributor for shift light? (Suprdave)
gauge cluster eh? which wire would that be off of the gauge cluster?
i already have the wire through the firewall already and the gauge cluster is a bitch to take out sometimes, so i think i'm just going with the distributor wire. um, this is the thicker wire off of the distributor right?
Old Nov 19, 2001 | 03:28 AM
Mista Bone's Avatar
D Tranny Guru
What year/model car?
Look by the drivers side wiring harness in the engine bay. You'll see a lone blue wire/plug not connected to anything. Cut the plug off and wire it to your tach.
The wire is the factory service connector for RPM signal.
Old Nov 19, 2001 | 12:10 PM
John_R's Avatar
Default Re: which wire to distributor for shift light? (Mista Bone)
hey. I have a stock 1999 Civix Ex. I looked under my hood the other day up near the firewall, on the righthand side of my engine bay. I noticed a lone blue wire, not attached to anything what so ever. I was curious. Is this the wire you talk about? For a rpm tach? I have a stock engine d16y8. (no money and warranty left, so no swap).
Thanks
John
Old Nov 19, 2001 | 01:25 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: which wire to distributor for shift light? (John_R)
would be on the righthand if you are standing at the front of the car looking backwards. Drivers side is more clearer to say.
It is close to the master cylinder.
Old Nov 19, 2001 | 06:28 PM
John_R's Avatar
Yeah. Drivers side. There is a large gray plug, that looks as if its male and female. (like 2 plugs put together) and the lil blue wire coming off is attached to a plug that is hooked to a metal bracket. Is this a wire I can hook up to a tach?
Old Nov 20, 2001 | 04:13 AM
Mista Bone's Avatar
D Tranny Guru
yep. That is the factory tech connection for troubleshooting.
BTW I found this while reading a Helms on the "think station"
Simple eh????
Old Nov 20, 2001 | 08:29 AM
John_R's Avatar
Woah. See this is the little **** that I need to learn about! *laughs* That makes my job so much easier. You know of any other tips for hooking tachs gauges, or just stuff like "The little blue wire"? Just anything to help me in my journies. *laughs*
Thanks a lot.
Old Nov 20, 2001 | 11:06 PM
Mista Bone's Avatar
D Tranny Guru
I found that little wire in the Helms while taking a dump.
Helms make great bathroom reading.
Old Nov 21, 2001 | 08:47 AM
GReddySetGO's Avatar
yea that blue wire near the driver side is your tach lead, i wired my shift light to that, but instead of going through my firewall, i too out my cluster found that same wire and tapped it from there, much easier and it keeps the wires shorter so everythings cleaner that way.
91rexhf
Feb 11, 2009 10:25 AM
Mac Listo
Apr 22, 2008 06:03 PM
LD_EGSICK
May 10, 2004 03:04 PM
Gonzo_SiR
Oct 29, 2003 10:12 PM
pdcivic
14
Jun 25, 2003 09:26 PM
