Window motor pinout (EK)
Old Sep 30, 2013 | 10:10 AM
BraveHeartSOHC's Avatar
Default Window motor pinout (EK)
I need a 96-00 LX/EX civic pinout for the window regulator motor (ground, positive, up, down etc). Reason being, I got the idea from looking at VWs and how they can roll the windows up and down via turning the key, I was going to do the same thing using switches and relays (well attempt it at least).
The very first version of the system is going to primitive, I believe that the keyless entry I'm going to be using will send the "lock/unlock" signal for as long as you press the button, so with that, I would want to hook the "lock" signal up to the "up" signal or the window motor so I could just hold it and roll up the windows and same for the unlock; Hook the "unlock" signal to the "down" for the windows.
When I get that working smoothly. I'm going to try and convert to 5-pin relays and use two momentary switches inside the door so that with one, momentary press of the lock or unlock, the windows will roll up or down. Of course say for the winter or if its raining, I would include a "master" switch to control whether the window part of the keyless entry will be included.
After all of that works. I will attempt to do the same thing with the sunroof with the trunk button since the trunk is manual cable.
So a pinout would be nice so I can finish my schematic. I'll post it later on
1992db2
Jul 21, 2017 05:05 PM
Pauly321
Dec 2, 2016 12:15 PM
FOSHO
Dec 18, 2005 06:21 AM
kings1ey
Jun 20, 2005 02:55 PM
JL 74
May 21, 2004 01:09 PM
